R50/53 Boost Gauge
Old 08-29-2013 | 09:42 AM
Jolly Rogrrrr's Avatar
Jolly Rogrrrr
Boost Gauge
Those of you that have added a boost gauge to your S, what ones are you using??
Old 08-29-2013 | 10:19 AM
MIKESGREENMINI's Avatar
MIKESGREENMINI
Scangauge II for now
Old 08-29-2013 | 01:00 PM
AlexQS's Avatar
AlexQS
Do boost gauges whether via OBD2 or a dedicated gauge having it's own vacuum line.... Do they actually measure Boost PSI, or do they only "Guess" what the boost level probably is based on what the vacuum readings are.
If it's the ladder, then would changing to a DT by pass valve which is set to close "all the way" when wide open throttle... Would that actually change the vacuum reading, or only increase the amount of air pressure from the supercharger being allowed to go into the intake manifold?
Old 08-29-2013 | 03:33 PM
Da_Ghost's Avatar
Da_Ghost
I had a used Autometer, but it became inaccurate after a while and the needle was shaking. Switched it for a Prosport since then and no problems, only thing is that during day, the tinted screen isn't always easy to read. Depending on how you wire it, you can have it illuminate white or orange, or that they switch between both when powered and with the lights on.
Old 08-29-2013 | 04:00 PM
c0op3r's Avatar
c0op3r
I use a OBDII Doggle, an iPhone and DashCommand App (with custom downloaded Gauge face).
Even has Max boost temp memory
Old 08-29-2013 | 05:38 PM
quikmni's Avatar
quikmni
I use AutoMeter from the ProMini gauge set.
Old 08-29-2013 | 08:00 PM
QuickCooper's Avatar
QuickCooper
I use a mechanical Autometer sport-comp.
Old 08-30-2013 | 11:16 AM
Jolly Rogrrrr
Thanks all, getting a Cravenspeed gauge from blue2turbo, matches the factory look. can't wait to hook it up, miss not knowing what going on.
Doc Pain
10-28-2015 07:09 PM
10-01-2015 12:13 PM
papawhiskey
09-30-2015 02:50 PM
Levers_and_Gears
09-28-2015 04:42 PM
EVMini
09-28-2015 10:20 AM
Quick Reply: R50/53 Boost Gauge
