R50/53 Rubbing noise driver side wheel
Location: NW Indiana (45 min south of Downtown Chicago)
on
I have a weird noise coming from my driver side wheel in my r53. Brakes look fine, nothing caught in caliper, I bent back the dust shield, and my bushings look good. I think it may be a warped rotor but I'd like some feedback to see if anyone else has dealt with this!
Can anyone help me? Here's a video...
on
I don't think the rim is bent because the video I shot was filmed with a GOPRO hero 3 at wide angle (fisheye). I do have a bubble though, not big enough to matter. I've looked into that.
on
No vibrations, and no it doesn't get louder as I accelerate. Just kinda stays the same. If you watch the video from 1:25-2, I accelerate and you can hear it stay the same volume, just quicker.
on
UPDATE:
I bought 2 new front rotors. I took off the driver's side (problem side) and replaced it with a brand new rotor. I checked the brakes in the process. They looked great! I reassembled the caliper onto the rotor and torqued everything to factory. When I spun the rotor, it was still making the sound. So I took the new rotors back and just had my old ones cut. I put on the newly cut rotors and I'm still getting the noise. It was then I realized I am missing the clips for my brake shoes to slide into. (not the clips that slide into the holes on the outside of the caliper). Are clips that allow your brakes shoes to slide in cleanly necessary? I've had them replaced on all my other vehicles but am new to my MINI.
Thanks for your feedback.
Don’t overlook the wheel hub. I had one that felt like a stuck pad and the noise it made came and went.
There are some good values over in the marketplace for the part and it’s easy to replace. In fact I bought two when I did one side just because.
///Rich
///Rich
on
The tires have 24k miles on them, so I have <10k miles left.
I just want to know if this is a common sound with run flats.
Minibeagle
08-13-2015 10:00 AM
