R50/53 Is it necessary to pull both the engine & trans
To get the Aisin 6spd out of an 05 R53? I have the blown seal and am eyeing removing the transmission this weekend and was told the trans comes out with the engine attached! OK if it does, just trying to get a handle on the project if I am to proceed. Any help would be appreciated. A friend of mine will do the rebuild and we are currently looking for the parts necessary. Any lead to the availability of parts is also key in starting this project. Thanks
You can leave the engine in but you have to drop the subframe if you leave the engine in. The clutch replacement tutorial on pelican parts can help you with the removal. I used it to do my clutch and boy was that one involved job. Tip: use a cherry picker to hold the transmission when reinstalling and or removing, a transmission jack helps but is a bit clumsy.
09R56
11-16-2022 10:49 AM
12-05-2016 06:31 PM
08-21-2015 10:07 AM
