R50/53 Anyone have an R53 that doens't leak oil??
#26
some folks take then out and shake them to see if they can hear the valve open/shut...not foolproof...
Most just replace it at INSPECTION. It is a $20 part (varies a bit, but pretty cheap)....and on most cars..you do it as regular maintenance.......
#27
#28
I have so many "wet" looking parts under my Coop I'm afraid to even start the investigation! I'm certain not one gasket has ever been changed with the previous 2 owners (especially after I just did the coolant/heater core service - see my posts on that). But, I'm not over consuming oil and the small drops that form don't seem to make it to the ground... yet!
#29
#30
What's considered the best method for this? Some of those engine cleaners scare me a bit. I'm never quite sure what they do to exposed rubber, plastic and other non-metal parts. On the other hand the "gentle" cleaners don't seem to clean anything that truly needs cleaning...
#31
I had success with the Engine Brite made by Gunk. Never had any problems related to rubber and plastic. Only thing, if you have painted parts and it's not cleared or done properly, it can mess it up a bit. On my previous car it never did anything to the car paint and it was a GM
Otherwise, there's always brake cleaner that works well.
#34
See my signature below.
I was so fed up after my fourth oil pan gasket started to leak I crawled under the car and turned the oil pan bolts near the leak by one 1/4 rotation. Yes, beyond recommended torque !
NO MORE LEAKS !... at least not with the oil pan.
This week I am changing my upper engine mount after the original leaked.
#35
Mine is a leaker. 05 MCS with 44k miles. I changed my crank sensor o ring the other day because some guy on here swears that most people who think their oil pan gaskets leak are wrong and that it's the o ring. After changing the o ring, I went for a drive, slid a piece of cardboard under the car in the garage before I went to bed. Nice little drip on the cardboard in the morning as usual... I hate these oil pan gaskets. Seems like a terrible design or something. I'm willing to live with it because apparently it's a hassle to replace. (Mine was replaced once already with previous owner).
#37
#38
The coolant was running down from the thermostat housing mixing with oil.
The PCV Valve once taken off should be able to move freely with the inside mechanism while shaking. If it doesn't move freely, I recommend replacing. I normally replace mine after every 10,000 miles since they are cheap.
#39
Isn't all this leaking a function of the aluminum engine? Aluminum expands and contracts more than iron. You can change seals but that isn't going to stop the various parts of the aluminum engine from expanding and contracting at different rates. Therefore you will always have some leakage and it will increase over time because the number of expansion and contraction events are greater and the seals slowly deteriorate and cant adapt to the dynamic movement of the metal.
AoxoMoxoA
08-21-2015 09:15 AM
Lex2008
08-16-2015 08:33 PM
