R50/53 R53 Fender replacement
Anybody know how to replace the front fender (you know, the part between the door and the wheel opening/hood where the side marker light goes)? I had a close encounter with a wayward deer the other night - I didn't hit the deer, actually, it hit me. It rolled over the bonnet/windshield then got up and ran away. I initially thought the car was fine, but then discovered that it had wrinkled the aforementioned fender panel. I'd like to replace it myself, but I can't seem to find any instructions on its removal. I'm hoping it doesn't require any welding... Anybody able to help me?
No welding
One bolt at the bottom--under the rocker extension
One bolt under the scuttle
One nut that you will see if you remove the plastic piece near the hood and look thru the hood hinge pocket towards the door
One under the plastic windshield trim==WARNING the plastic will likely break when you try to remove it--adds $40 to the cost
Actually simple but access can be difficult. Diagram does not show the screw under the windshield trim (maybe because mine is an 03--maybe newer models don't have this screw.
silence2-38554
98
09-21-2016 02:52 PM
08-07-2015 09:51 AM
08-07-2015 08:10 AM
bctf1
08-06-2015 12:55 PM
