R50/53 Building custom exhaust...need some info.
I’m thinking about pulling the JCW exhaust off of my R53 and making a custom exhaust for it…..just because I’m bored, and I want to test out my new welder. I’ll keep the JCW exhaust in case I decide to put it back on (if the custom exhaust sound like crap, or it’s just too loud on the highway. I want something a little louder with less back pressure so I can get some more “pop and burble”…..but not annoyingly “ricer” loud.
I have three questions.
1. What’s the best pipe size to use for a cat back system? I think the JCW is 2.25” if I remember right….should I go up to 2.5” or 3”?
2. What’s a good muffler that is small enough to fit up under the back of the car, flows really well, but doesn’t have a ricer sound to it? Magnaflow?
3. Where can I get a new flange that bolts up to the cat? I don’t want to cut the flange off of the JCW system to use it on the new setup.
I’m going to build something like this….it should be pretty easy.
2.25" can flow the horsepower that most modified minis produce. remember that the limiting factor is the header-to-catback flange in most cases. You can have a 4" cat back but it won't make a difference if you have a 2.25" flange before it. (Truth be told it wouldn't make an improvement anyway).
So bare with me on this comparison. I know it's an Audi and not a MINI, but just to talk about the mufflers.
The shop I previously worked at, the owner does some amazing custom builds. This exhaust is completely custom for this big turbo build that we had in. The mufflers you see pictured are Vibrant Performance. I'd suggest looking into them. It gave the build a very nice sound and nothing too loud. Adding resonators helped as well as you see towards the front of the photo above. As far as a flange, have you looked into doing a v-band set up on the exhaust instead? It's what we did for most custom exhausts and really helps with adjusting it and removing it when needed. Otherwise, I don't think we sell flanges so check out this site here.
888.280.7799 | 6am - 5pm PST
my stock system was rotted and was ready to fall off ,here is what I did with my set up,, these are parts I had kicking around from other projects and header builds , I had a 2.250 j bend I sectioned into a y pipe from the cat back pipe, I had 2 flowmaster 2 chamber mufflers that I capped the outlets and cut in a half of a 2 1/2 u bend on each muffler and it be came the cross over for the 2 chrome tailpipes off a pair of 2006 gto mufflers ,, I did have to add a baffle on each muffler because it was real loud ,, but it has the right tone and not to loud ,no droning ,,gmonde
When you do a custom exhaust and its more free flow an louder , you will tend to get a drone at speeds. The task is to sound louder and not drone. Good luck on the custom exhaust. Follow the line of the JCW exhaust and should be good.
Just to make a suggestion, if you do the single muffler only use a single outlet instead of the two you have in your posted photo.
Reason being is the added on outlet on the right will not produce much outflow so its more for looks than function.
Anyway, if you are making it different go for a single oval tip.
Please post photos of your project and of course let us all know how it sounds !
I'd suggest talking to the Magnaflow guys for muffler suggestions; they make quality stainless mufflers. Richard, the VP of engineering has been on many car reality shows (Gas Monkey, Chip Foose's show, and a couple of others doing custom exhausts). They can probably give you suggestions for the performance and sound you are looking for and probably have something in stock that would satisfy your requirements. I'm not affiliated with them; just a satisfied customer who helped in my Lotus 7 exhaust.
RobbyD
01-29-2019 01:22 PM
R53UndaPSI
09-21-2015 09:42 AM
