R50/53 R53 Engine mount question
Old 07-27-2015 | 04:42 PM
jcwswede's Avatar
jcwswede
Hi
Im a completly noob, so have this in
mind
Anyway, I have a question about my Engine mount. I have been googling alot and couldent find one that looked like mine and got suspicious if it was completly bad,especially with the rope sticking out.
But then I found this picture with a guy replacing his and thought that maybe mine is ok for now although an upgrade would be better. What would you say/do?
Old 07-27-2015 | 05:30 PM
David.R53's Avatar
David.R53
That's the way they make them. New ones look the same. Look for cracks/tears in the rubber or liquid oozing out if you are worried about it.
Old 07-27-2015 | 05:32 PM
David.R53's Avatar
David.R53
BTW, The upgraded ones can be harsher. Just be sure you understand the trade offs of smooth/quiet vs harsher/performance.
Old 07-27-2015 | 06:04 PM
batrugger's Avatar
batrugger
This is the mount for the 02-04 cars so there isn't any fluid in them. If your worried about it you can remove the arm that attaches it to the passenger side strut mount, remove the bolt that holds it to the motor, and raise the motor up to see the rubber at the top of the mount. If it is bad you will see cracks there.
Old 07-28-2015 | 08:10 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Actually even the 02-04 rubber mounts are hydraulic filled. As these get older that actually get shorter and ruin the other mounts.
We have the TSW polyurethane version which is a great replacement for it, and will last much longer.
http://www.waymotorworks.com/early-t...4-r50-r53.html
or the stock version
http://www.waymotorworks.com/oem-eng...4-r50-r53.html
Old 07-28-2015 | 09:19 PM
batrugger's Avatar
batrugger
Thanks, did not know that Way.
Old 07-29-2015 | 11:30 PM
jcwswede's Avatar
jcwswede
Thanks alot for the response and help.
I think I Will replace it soon
@ waymotorworks, great page! Thx
andrewjg1994
01-29-2021 07:45 PM
07-16-2020 12:54 PM
bobbiemartin
01-20-2016 05:28 PM
silence2-38554
11-12-2015 09:39 AM
Mini'mon
08-16-2015 12:47 PM
Quick Reply: R50/53 R53 Engine mount question
