R50/53 Half of lighting air unit out
This panel is illuminated by just two bulbs. When one fails, half of the panel no longer illuminates. It's not too difficult to remove and replace yourself, just time consuming. Great DIY write up here for the replacement of the bulb that went out. Bulb type needed is 509T, suggestion is to replace both bulbs as you're in there and you might as well just in case the other one is on its way out.
888.280.7799 | 6am - 5pm PST
You would have to take its apart and replace them bulb, takes some work. Or you could get a new panel or funk one at a junk yard.
New one here: 64111502214
https://www.ecstuning.com/Search/SiteSearch/64111502214/
07-16-2020 12:54 PM
blackie
01-18-2017 09:56 PM
