R50/53 Suspension
Suspension
I have a 05s that is currently lowered, I am looking to take it back to OEM, I have purchased strut mounts and coil springs and struts and springs for the rear. (Just replaced the front struts about 2k miles ago) I also purchased mounting nuts. What else will I need? Just looking to go back to stock height for the winter.
Are you on lowering springs? If you want to be able to go between lowered and a respectable ride height for winter, I'd invest in a good set of coil overs. I'm not sure their top ride height level, but ST coils here are the best bang for your buck coil over. Maybe look into them as an option. Otherwise, depending on what your current lowering set up is, (i.e. just springs or a shock/strut and spring combo), you'll just need struts/shocks, coils, and new front/rear mounts may be a good idea depending on when they were replaced last. If needed, we have a Rear Shock and Spring Replacement here and Front Shock and Spring Replacement here to help you with your project.
888.280.7799 | 6am - 5pm PST
https://www.ecstuning.com/Mini-2005-Cooper-R53-S-Coupe-L4_1.6L_W11B16A/Suspension/Springs/
https://www.northamericanmotoring.co...endations.html
33526754123 or 33526754124
Yea the reason I am wanting to go back to stock is last winter I did about 700 worth of damage to my bumper, sash ate and radiator housing. Ripped the lower part of the bumper and splash plate off. Broke the clips off the radiator housing. Ended up just fixing it myself but don't want to go through that again.
Lowered in the winter you have to worry about hitting things and damaging the underbody. Or at least get a skidplate. Stock ride height is the best for control and clearance.
Let me know if you need anything more
hello, Send me a PM with you VIN and I can look them up , they are weighted to vehicle and options. Have to use a special internal selector.
thanks for the PM
R50/53 Strut/ Mount Recommendations
Minor Threat
10-21-2015 12:02 PM
