R50/53 Engine Noise
Engine Noise
Need some help trying to figure out where or what this noise if coming from. Any help or guidance is appreciated. I have an 04 R53 MCS. Just recently purchased it used with 98k on the car. This is the only problem I've had with it within the 6 months of owning it. I have a video on YouTube of the noise: https://m.youtube.com/watch?v=2tLxD_4jKwM
That's a crazy noise! does it sound like it's coming from the passenger side of the car? is your check engine light on? my three guesses are a problem with the belt (doesn't sound like a belt noise to me) a vacuum leak, or something wrong with the super charger.
Hopefully someone more knowledgeable than me will chime in, otherwise, if it were me I'd take it to a shop and ask them. To me it'd be worth even a $100 diagnostic fee to figure out what it is and then see if you can fix it yourself or have them fix it.
Gonna throw this out there...
Could it be a failing idler pulley or belt tensioner pulley? They both could "whistle" as the engine revs - if indeed they are failing...
Jack the right side of the car up, pull the passenger front wheel and wheel liner off, start the engine, and listen from the right side of the engine as someone revs it and try to pinpoint the exact location of the noise.
I'd also have to say it sounds like a vacuum leak. I'd maybe do a smoke test.
888.280.7799 | 6am - 5pm PST
I'll be on the look out for a decent shop near by. Any of ya'll recommend to just take it to a Mini dealer? Just wanna get some feedback before I drive 2 hours. (Closest dealer is 2 hours away)
Pelican Parts, did some digging around NAM while on duty since I'm unable to take it to a shop or take the RF wheel off and check the pulleys. Read a post about a fella who's supercharger inlet tube (green gasket) had a leak and said had some of the same sounds mine has currently. You/ya'll reckon I should look into that as well? Hopefully I can get under the hood today and see what I can find
PelicanParts.com
05-17-2016 08:58 AM
Kid_Organic
R60/R61 Stock Problems/Issues
10-27-2015 10:06 PM
