R50/53 Boost Gauge Alta Performance
This was a fairly easy install but only one problem under boost the gauge needle will shake really bad. Does this mean I have a boost leak in my gauge line?
Had to take the intercooler off to tap into a port on the intake manifold.
Alta performance sells a gauge holder that screws behind the cluster
What are you tapped into? We will take a boost/vac reference off of the fuel pressure regulator line, and don't have any air hammer issues.
You may need a snubber to smooth out the air being sent to the gauge, or there is a kink in the teflon tubing, or a garbage gauge.
are you at full throttle? or partial throttle, I get a bit of bounce under partial, that's due to the bypass valve. if your T'd into the fuel pressure reg. (its about the same location you have shown)
if you actually drilled a hole and tapped into the intake manifold, you should definently see hard vac/pressure bounce, especially infront of one of the cylinder plenums. the valves opening and closing will create variations in the pressure.
