R50/53 Burning Halogen bulbs
I have a 2003 Cooper S with halogen lights (using Sylvania SilverStar H7's). I replaced a left low beam two weeks ago and noticed yesterday it had burned out again so I replaced it. Today it's burned out again after less than an hour's use. What could be the cause of this? The connector looks OK and it's not a fuse. Is there something that could cause a voltage spike to fry these things or another cause?
Update: I checked the bulb I replaced that I thought was burned out with a 12V source and it still works. The replacement bulb still in the car that quit working yesterday now works, at least for now. I hate these intermittent problems.
The lights go thru the General Module Control Unit (boy, that sounds expensive!) and according to my Bentley manual you can access the Module trouble codes thru the OBD II connector. I checked with my Peake scanner and found no faults but I think the Peake is mostly engine related fault finding, not lighting, so I may have to (Gulp!) take it to my dealer. Anyone else experienced this problem?
robertcoyle
01-23-2016 07:07 PM
watchluvr4ever
01-11-2016 01:05 PM
