R50/53 Seth's '03 R53 - Maintenance/Mod Log
#351
Haven't done anything else but the car did leave the brake light on in addition to the ABS and TPMS lights this morning, so the speedo did not work. ABS was disabled. Went back to just the ABS and TPMS lights for the second drive with speedo function returning. Though probably unrelated, I've been getting a hissing sound from the brake pedal for maybe 6 months that has gotten worse in the past couple weeks. Probably the brake booster. Another thing to add to the list.
Figure I should post the codes from the DSC if anyone has any thoughts:
5DC3 - Drehzahlfuehler hinten rechts Anfahrerkennung v_Vergleich
5DA3 - Drehzahlfuehler vorne rechts Anfahrerkennung v_Vergleich
5D93 - Drehzahlfuehler vorne links Anfahrerkennung v_Vergleich
5DB2 - Drehzahlfuehler Impulsrad hinten links periodische Ueberwachung
5DB1 - Drehzahlfuehler hinten links Extrapolation
#352
If I haven't mistaken, the speedometer speed derives from the wheel sensors. My thought is you have more than one speed sensor problem and the algorithm threw up its hands so you got no speedo intermittently. Don't freak out. It is not the end of the world. I suggest you carefully review what you had done and the problem more likely lies with the sensors, especially if you replace them recently. You are in area with road salt? Don't rule out damaged or rusted tone rings that is a part of the wheel hubs.
The German messages to me suggest your left rear sensor is intermittent. This can be the sensor as well as the tone ring.
#353
#354
"Unfortunately I'm probably in big trouble. I have tried swapping the rear sensors and 2 additional sensors to no avail. Even with the sensor removed from the hub, the reading is still erratic at key on. Once unplugged, the reading of course goes to 0. However, when I swapped the rear sensors I noticed the reading was no longer erratic at key on, so I thought maybe I had fixed it and reassembled the car. When I started it however, it started reading erratically again. It reads erratically during driving too. It normally reads right around the other sensors, but every ~1/4 of a second it will drop a lot. So at this point I'm assuming I somehow created a short in the wiring back from the sensor to the ABS module. I can't see anything wrong in the short section of exposed wiring before it enters the wiring harness. If it does end up being this problem, I'll probably have to replace the entire wiring harness under the car. I just don't understand how I could do this."
I don't read your every post closely so I gave you my assessment. It is very unlikely it is the wiring harness. Automotive harness and connectors are very good nowadays. The problem usually lies in the one that monkey with the wrenches and myself included.
#355
You asked if anyone has any thought of the codes and I provided. Only a post back you were freaking out:
#356
I've read conflicting posts over the years about the R56 trailing arm conversion. Some say you have to use 1st gen sensors, some say they used 2nd gen sensors, and others are vague and dont say which sensors they used. There's a guy on minitorque and track mini who makes custom parts for the track and one of the things he sells is a set with the lower shock mount adapters along with custom machined bushings to fit the1st gen sensors in the larger holes of the aluminum trailing arms securely, and in the right position.
Of all the different sensors you tried after the conversion, were they all R56 sensors, or did you also try your originals?
#357
#358
Perhaps some good news to report today. While my ABS problems are still not solved, I got in contact with Bytetronik again about retuning the car. After some email discussion, I ended up buying their FA53 software and a set of Bosch 550cc injectors. Completed an oil change and installed the 550s tonight after work. Flashed the base map they sent me and off I went to do some data logging to send back so they could do some refinements to the tune. It appears that my problem is solved, though obviously I haven't driven a whole lot yet so I can't say for certain. Once I get my ABS issue sorted, I think I might go ahead and get a mild cam and the Wilwood BBK I've been eyeing for some time.
As for the ABS issues, the short of recent developments is that it sat at an independent shop for 2 weeks while they lied to me about the condition of parts on my car and misdiagnosed the problem twice. I ended up having to pay ~$500 for an ABS module that did not fix my problem, though they said it was "part" of the problem and I therefore had no choice but to pay. We initially agreed to have their ABS module removed because it was a used part and they couldn't tell me anything about the vehicle it came from, but the owner ended up going back on our agreement and refused to do further work on the car. Just a terrible experience. Back to square one.
#359
#360
INPA. I replaced that wheel hub assembly a year or so ago to fix a noise I was hearing. The shop initially told me the wheel bearing had a "huge gouge" over the magnet that the sensor reads, but it turns out they were lying about that as I took the car back and replaced it myself again with a Timken unit. It didn't fix the problem and the other one wasn't gouged.
#361
I was not following your thread, you already replaced the r56 hubs?
I tried a set of amazon wheel sensors, they did not work. I went to a LKQ and picked up a used set off a late r53 and they are still on the car. I have not done my r56 trailing arm conversion yet as my wheels wont fit on them. That said when I was researching I could have sworn it said to get the arms with sensors, is that what you did ?
#362
#363
if you use ista-d it will give you the wiring diagram so you can test for continuity or a short. if you still have your r53 trailing arm you could bench test to see if it is still erratic
those hub rings are very sensitive, I would swap hubs between the sides and verify the error stayed on the same side
#364
#365
All you need is the fundamentals of how to use a DMM to determine open and short with my help. You need to eliminate if the problem is due to the harness, which includes the connectors and up the sensor.
BTW, I think the reason the sensor is so finicky is because they are just low cost and hence low tech inductive coil. There is nothing wrong with low tech and, in fact only go shows the competence of the designer. I have never measure the resistance of the wheel speed sensor. If you grab one that is known good and confirm it has very low resistance (under 100 ohm) it is low tech inductive pickup. This type of sensor should be very easy to determine good/bad.
#366
So I’m getting ready to head back to school and have been thinking of writing some things about the car as I make this next transition. I'm approaching 4 years of ownership and have done a fair few mechanical and cosmetic procedures in that time. As I've mentioned before, my dad has had an R50 since they were new in 2002 so I've always felt a special attachment to the first generation new MINI. Unfortunately, I've been pretty frustrated with mine. I'm always finding flaws or messing something up when I work on the car. If you've been following this thread you'd see I still have a problem with a wheel speed sensor that I've had for several months now when I did the R56 trailing arm swap. I've stabbed a condenser trying to put the bumper back on. I've battled oil leaks and have what I believe to be an unsolvable transmission fluid leak due to the Quaife diff I installed with my clutch. My paint looks awful and the wheels are chewed up (though those issues aren't my fault). Even just in the last few days I’ve noticed the car running rich during open loop; on first start, the car no longer does the normal RPM “flare” and instead seems to bog slightly and some puffs of smoke emit from the tailpipe along with the smell of fuel. Things like this seem to crop up every time I work on the car. This latest issue no doubt stems from the new injectors and tune I’ve recently done. However, I know this car has spoiled me in its driving characteristics. The inputs are better than any other car I have driven. The intake noise is wonderful. The interior and exterior design is seriously charming and certainly looks far better than similarly priced cars of its time. I’m sure this car is a future classic.
I’ll be leaving next week and the car will be going with me, but my tools won't. I will no longer be working at the Toyota dealership I have been at for the past three years, so I also won't have the help of my coworkers that I have pretty much depended on for awhile. All that to say I will almost certainly be doing nothing to the car for the next few years. I hope to solve the wheel speed sensor issue before I go, but that will be it.
I've also taken the last ride on my motorcycle for a few years as well, since it won't be going with me to school. My dad has gotten interested in motorcycles since I bought mine and he'll likely be riding it once in awhile while I'm gone.
All in all, I find it in hard to get in the car and just enjoy it for what it is anymore. I have put too much time into it doing jobs that I need (or sometimes don’t need) to do that end up causing issues for me immediately or sometime down the line. Every time I get in the car I’m reminded that my brakes don’t work right and I can’t figure it out and the car now has fuelling issues and my headliner is falling on my head blah blah blah… I’m tempted to just throw in the towel and get a Civic or something.
#368
#369
#370
#371
if I recall there is a bolt you can get to, or add on the metal supports on the left hand access panel under the dash, same place the canbus wires run. No need to tap into a wire when you can ground to the body right there.
are you going to the tail of the dragon event next weekend?
What's going on at TOTD? Haven't been yet.
#372
it's a yearly event, there is a big event in may and the smaller one next weeknd
https://www.facebook.com/HWY129MSSD/
https://www.motorsportreg.com/events...Kf__YqH5UBLoqU
#373
#374
#375
Combed around in the Bentley manual and I believe all brown wires with a black tracer are grounds so I just tapped into one of those in the loom and everything appears to be good! No more flickering gauges.
