R50/53 side scuttle loose
side scuttle loose
I've seen a lot of info on removing the side scuttle, but after re-attatching mine it seems to be much looser than before.
When re-attatching, i got the firm and assuring 'click', but it seems to sit a little sloppy, and have more movement than before removing it.
Just curious if anyone else has experience this?
I'm wondering if the grommet style fitting looses some of it's 'grab' each time you remove and re-install the scuttle?
https://www.northamericanmotoring.co...e-install.html
Check that 51400766479
https://www.ecstuning.com/Search/Sit...h/51400766479/
Might be loose or worn.
Thanks for all the info everyone! After a closer inspection it seems that the flimsy metal tab that houses the grommet is pulled forward slightly with the force it takes to get the scuttle out, so before putting the scuttle back in you just need to bend the tab backwards a bit. It did't pull forward much, just enough for the scuttle to flop around a few mm.
Seems obvious now, but i'm glad it's fixed.
Ah, it was bent in , yes its a thin sheet metal tab. Glad its ok.
Interior/Exterior So Where Do You Keep Your JCW Exhaust Bluetooth Remote? I Mounted Mine
camptown
07-29-2021 11:43 AM
simplimon
05-07-2018 12:06 PM
driver centric
05-20-2016 09:39 AM
