R50/53 Help
#51
Even if it doesn't have synthetic oil in it already? I'm not sure what oil is in the car. I've heard some horror stories about synthetic oil and regual oil mixing together and clumping up causing major issues. Or do minis come with synthetic from the factory?
#52
I have never heard those horror stories...you would have to explain to me what chemical agents between the two oils scientifically could even do that. people switch from regular to synthetic all the time....if you are super nervous (which you sound like you are). Drain the oil - take a jar (baby food or whatever) mix half of the old oil - half synthetic...shake it up and see what happens. Minis are supposed to come with synthetic from the factory.
#53
Supercharger Oil
http://new.minimania.com/Search_Resu...%20oil/default
#54
Hey guys finally all done with everything. Only one final thing I gotta do. Bleed the breaks. When I put the driver side suspension back on I didn't pay attention to where the break line was routed. So being as far as I was I want about to pull the subframe and axle again for the break line. So I just undooked it from the caliper and rerouted it and hooked it back up. So when I blead the breaks do I do only that caliper or all of them and do I need to bleed the clutch also?
#56
Engine oil for the MINI's MUST be synthetic. There are also differences in some regions of what "synthetic" is (full synthetic, mixed etc) The key is to find the oil that meets what your engine needs. Fist gen's need BMWLL01 (long life 01) certification. The dealer has the oil, and usually reasonably priced, I use Amsoil, others use euro spec Castrol (euro spec is full synthetic - North America Castrol says synthetic, but it's mixed). As for filters, use Mann, Mahle, or OEM, and consider installing a fumoto valve to make your life easier in the future. The first time you change the filter, the gasket and filter container/canister is a bit tricky to get seated (there is a spring resisting the installation, and the filter needs to expand/seated onto the base). Lubricate the gasket with some clean oil, take your time, and feel around the canister to make sure there are no gaps remaining.
(Wow, looks like my post took forever to be sent, and was late to the party - yes the synthetic can be mixed with "Dino" oil, so drain time doesn't matter)
#57
888.280.7799 | 6am - 5pm PST
#58
R50/R53 Maintenance
http://new.minimania.com/articlesearch/oil
Alpha Motoring
04-25-2016 10:01 AM
04-06-2016 01:47 PM
04-01-2016 03:04 PM
dyeLucky
03-31-2016 11:54 AM
