R50/53 Fast
You can add a smaller supercharger pulley and catback exhaust, maybe swap the intake. Beyond that your options are header, cam, bigger fuel injectors, and a tune. Going a step further: a big valve head. HP comes with a dollar amount attached. Start with shedding weight, then get out your credit card if you want more.
I have an R53 with the JCW kit also. The best bang for the buck is to get a tune from Jan at RMW. You have a good intake just get a k and n filter. An exhaust won't do much more than what you got. A 15 percent pulley only adds 1 more psi. You have bigger injectors. A header is the next step. Then a GP inter cooler
Then you go big time w/ a cam and even bigger injectors. You will need a retune after that.
but depending on when it was installed you may have the JCW 210:
Do you know what version or parts you currently have? It's kinda needed to know how to improve from here.
Yea, you can tell by the JCW intake and the blue JCW injectors combo for the newer one.
Since you have JCW engine mod maybe focus on other areas to be faster such as suspension and high performance driver training.
Rear Adj Sway Bar, Stiffer/Shorter Springs, Lighter/Stickier Tires, and Lighter Wheels.
For the engine it depends on what JCW package you have. For 210 package (with air intake and injectors); if you have never replaced the crank pulley (OEM tends to fail at high mileage) you could install an 2% ATI crank pulley to increase boost slightly without changing out your JCW pulley.
If I had to do it all again....I would upgrade the JCW pulley to a 17% pulley, put in any good CAI....and leave everything else the way it is, and work on more suspension and braking upgrades. If you have the JCW exhaust, tune, and head...you are already doing pretty good.
Driver training....and good upkeep....so many cars need things like struts and sparkplugs, it's sad...
90% of folks have more performance in their cars than they can USE.....
Then you will find spending $$ on quality tires to gain more grip...maybe suspension mods...
Getting a pulley on the SC is a way to gain HP...wth a JCW, you would want a 17%....you will not feel the change to a 15%...you already have about a 11% smaller one (about) than the S.
R50/R53 Tuning
http://new.minimania.com/Mini_Cooper_Tuning
Please let us know where you would like to start, and we'll get you the information.
moremini
04-20-2016 07:08 AM
1004ron
03-22-2016 09:39 AM
JWA
03-20-2016 04:29 PM
Navigation & Audio Mini Cooper HiFi system finally completed.
spikeyadrian
03-18-2016 07:24 AM
