R50/53 2003 R53- Need Hose Identification
Hi Everyone
I had a little bit of a mouse problem in my poor mini that sat idle for a while. Mr Mouse chewed threw countless things. I've handled most of it so far, but yesterday I noticed that the slight hissing I was hearing became MUCH louder. If only it was a mouse eating snake. Alas, it is the pictured hose here. However, I can't seem to locate it as a part. It's about 3.5" long x 3/4-1" in diameter. Clamped to the throttle body housing with a copper squeeze clamp. Plastic nozzle tipped pictured inserts into the hose. No clamp on that side.
CAN YOU HELP IDENTIFY THE HOSE, SO I CAN REPLACE IT? Mini of Manhattan doesn't have it on their parts diagrams.
Thanks again!
HOSE AND CLAMP I NEED - STOCK IMAGE
PULLED BACK TO SHOW WHERE IT ATTACHES TO THROTTLE BODY
ONLY PAY ATTENTION TO RED ARROW - STOCK IMAGE
ACTUAL PICTURE OF MY CHEWED HOSE WITH AIR TUBE FALLEN OUT - TUBE BLOWS COLD AIR
Thanks again!
Appears to be the fuel tank breather line.
Yea , thats it, For the S is come in one for the manual tranmission :
13907515434
https://www.ecstuning.com/Search/SiteSearch/13907515434/
One version for the Automatics. 13907541090
https://www.ecstuning.com/Search/SiteSearch/13907541090/
Here you go for 13907541090
https://www.ecstuning.com/b-genuine-...h/16121180240/
The other line comes with the clip on it, not a separate part number
My understanding based on ECStuning's close-up of the full replacement part, is the Fuel Hose is 7.3 mm ID (inner diameter). 1/4" fuel line is the equivalent of 6.35 mm ID. I bought some, as opposed to spending ~$20 on 1 ft (or meter, i dont remember) for the proper stuff. Haven't gotten back to getting it all the way on, as I had no proper lube to assist me, its quite the tight fit. One of my racing buddies recommended just using some petroleum jelly. Plan on getting back to this in the next few days to further troubleshoot my leaking issue. Will probably try disconnecting individual hoses 1 at a time to see if the leaking noise goes away before buying any more new hoses.
R50/53 Tips on selling my mini
Jimmy Devaney
30
05-27-2016 12:00 PM
