R50/53 Did I just blow the engine in my r53?!? HELP!!
Old 06-22-2016 | 10:09 AM
AoxoMoxoA's Avatar
AoxoMoxoA
As others have stated - totally normal.
Best way to clean out intercooler is to remove it, stretch a heavy duty rubber glove over one of the ends (duct-taped to keep it on), throw a pint of acetone in the other end, tape another glove to that end and invert repeatedly - then drain.
Whatever small amount of residual acetone left inside after draining will evaporate by the time you're ready to re-install it.
  #102
Old 06-23-2016 | 06:02 AM
Steffen.Johnson's Avatar
Steffen.Johnson
Ok I will do that! Thanks
  #103
Old 06-24-2016 | 09:13 AM
Sorry , did we miss a clip or was it missing ? Should match that pic ?
  #104
Old 06-25-2016 | 09:47 AM
Steffen.Johnson
Jason in customer service took care of it for me. But it was very odd. They sent a tag that said coolant hose - multiple and the only thing in the box was one clip attached to the tag.
  #105
Old 07-01-2016 | 04:20 PM
Steffen.Johnson
An update for all those interested. BARNABY IS RUNNING AGAIN!! NAM user memo79 came over this morning and we swapped out all the hoses that I had ordered from ECS, filled and bled the new coolant and took it out for a test drive. We also hooked up a mobile computer to the ECU and found no issues with the running temps. I can't believe I once again lucked out with this MINI. I will be driving the car short distances and monitoring the coolant level. But so far so good! Thanks memo79!!!
  #106
Old 07-01-2016 | 05:24 PM
CooperSAZ's Avatar
CooperSAZ
What, what a great story. Good job! Kudos to memo for lending a hand. Great community we have here.
Great news for the long weekend. Motor on!
  #107
Old 07-01-2016 | 05:36 PM
Racingguy04's Avatar
Racingguy04
Yay! glad to hear it! these cars definitely can cause headaches, but I can't find anything else I'd rather drive so I think it's worth it! How's your tranny?
  #108
Old 07-01-2016 | 06:54 PM
mdaz75's Avatar
mdaz75
Hell yeah, congrats!
  #109
Old 07-01-2016 | 07:00 PM
Steffen.Johnson
I am so pumped. It felt great driving him around again. I am still a little scared to get stranded again!
Yea unfortunately this car has caused a lot of issues to make me worry so I am still not 100% sure what I want to do with it. But I really love the ride! I am debating just going through the whole thing and dropping like 4k into it to make it new again so I dont have any worries and its dependable.
Thanks!
  #110
Old 07-05-2016 | 08:08 AM
Steffen.Johnson
UPDATE: I have been driving Barnaby all weekend short distances and checking the coolant levels each time after. The car has been running pretty well with the normal driving, with AC on high, and with heat on. I did however notice a small hairline crack in the expansion tank with a few drops of coolant on the engine heat shield each time I drive the car. My instinct is to go out and get a stainless tank and call it a day but I am not quite sure if this is a sign of a blown headgasket or too much pressure in the coolant system? Can anyone chime in as to what I should be looking for before just replacing the expansion tank, or if I am just being paranoid?
  #111
Old 07-05-2016 | 08:39 AM
HaveATank's Avatar
HaveATank
I would say too much pressure. I get a leak from the cap once in a while. I just clean it and keep it moving. I already replaced the cap so i know that not it. I just think the old fashion pressure caps are better then this particular screw on type. For the r56 the cap it alittle different and there is no leak. But if your expansion tank is cracked i would replace it.
  #112
Old 07-05-2016 | 08:50 AM
Steffen.Johnson
So if you think its too much pressure, I wonder what is actually causing the excessive pressure.
Do you recommend the stainless steel instead of the plastic? And what cap do you prefer over the plastic one?
  #113
Old 07-05-2016 | 09:31 AM
HaveATank's Avatar
HaveATank
It not too much pressure just that the cap sucks, but you said your tank leaking which is different then my situation. This is what happens to me no matter how hard i tight the cap. I just clean it and keep it moving.
  #114
Old 07-05-2016 | 10:33 AM
jgk6502's Avatar
jgk6502
Makes sure you don't have too much coolant in the expansion tank. When warm, the tank should be filled to just the top of the fins at the bottom of the tank when looking inside. I think over filling can cause too much pressure, since coolant is denser than air. If it's cracked, you need to replace it.
  #115
Old 07-07-2016 | 08:55 AM
Steffen.Johnson
Yea well the caps are really crappy too. I cant believe even with a good tank like yours the cap still leaks. Is it at the proper level?
OK will do. There is a fill line and it looked to be a little above the fill line when cold and hot that may be it. It hasn't leaked in 1-2 days of 100+ degree weather with the AC on so we will see
  #116
Old 07-07-2016 | 10:30 AM
HaveATank's Avatar
HaveATank
Yah my coolant it actually very low in the expansion tank. I did this purposely to try ans minimize the leak, but I'm convinced it the cap. The cap on an r56 is so much better then this. Canton makes a nice expansion tank which uses a standard rad cap. If it becomes too much of a problem in the future i will be cutting the nect off and getting a regular pressure cap on. But right now it only alittle bit that comes out. My experience has been that once you put it on don't remove it or there is no way to get a proper seal.
  #117
Old 07-07-2016 | 12:51 PM
Steffen.Johnson
Hm that is really interesting. Ill keep that in mind, thanks for the help!
  #118
Old 07-10-2016 | 08:36 AM
minsanity's Avatar
minsanity
Check this....
http://www.greeneperformance.com/col...e-coolant-tank
Name:  image-0.02.01.a540158c6dab8ec64ab4dae33ad9ffbf633d67eac7bb6284b6fce19f5e694714-V_zpshr2.jpg
I've a Canton, a buddy has the Greene. Both function equally better than OE, but the latter looks way cooler.
  #119
Old 07-10-2016 | 11:10 AM
Steffen.Johnson
Originally Posted by minsanity
Check this....
Wow! Yea that really does look cool! Ill look into it thanks!
  #120
Old 07-11-2016 | 05:59 AM
minsanity's Avatar
minsanity
You've a choice between powdercoated & bare aluminum on Greene....& this holds pressure as does the Canton.
  #121
Old 07-13-2016 | 07:53 PM
Steffen.Johnson
Thanks again! I really like the black one.
  #122
Old 08-10-2016 | 12:22 PM
Nics's Avatar
Nics
Don't forget to get a new coolant cap when you replace the tank. My old cap wasn't creating an adequate seal on my new tank and kept spewing out coolant. I got a replacement cap for $5 on amazon.
  #123
Old 08-10-2016 | 04:07 PM
Stoker's Avatar
Stoker
Ok more of an update for all those interested. I am also looking for some suggestions and ideas as to what this hose coupler is. I moved my MINI to a flat surface removed the air box so I could see better what was going on and filled the expansion tank with coolant. About 5 seconds later I heard fluid pouring out and found the MINI dealer had pulled the hose coming from the expansion tank to the coupler between the thermostat and heater core hoses. The plastic coupler I showed in the pics seemed to be more of an Y shape when all pics online show it to be a T shape. The plastic coupler was also brittle and cracked so all the fluid was leaking from there. I am thinking of just ordering the whole hose assembly with plastic couplers from ECS but I am not sure if this one thats broken is included or not..
Right below the white wire you can see a wet spot with the plastic Y shaped coupler that is broken and needs replacing...
This is the hose coming from the expansion tank that the MINI dealer left un hooked and the hose clamp was also missing ...
And this is the only schematic I found online for my car it looks like letter C is what is needed but mine doesn't look the same..
If anyone can help especially ECS with what I need I would greatly appreciate it. I am also disappointed that the dealer left the hose and clamp missing as well as it looks like they snapped the plastic inlet where the expansion tank hose goes into the coupler.
I know that there are more posts in this thread.... But!!!
Exactly the same thing happened to me, The OEM Part says a T fitting, someone (Before i bought it) Used a Y.... It broke... found the T fitting at Auto Zone....
  #124
Old 08-10-2016 | 04:16 PM
CooperSAZ's Avatar
CooperSAZ
I literally JUST replaced this piece as well! It broke off swapping the thermostat and housing. Glad it did I guess instead of falling apart while driving and overheating the vehicle. It literally fell apart into multiple pieces that needed to be removed from the expansion tank hose. Crazy…
T-Connector
Old T-Connector removed
New T-Connector installed and ready to go
  #125
Old 08-11-2016 | 08:11 AM
Steffen.Johnson
I found out that the auto has the "Y" connector like I have and the hoses are all one assembly. And the manual has the "T". Its crazy that all these have gone bad recently!
