R50/53 Another burning (oil) question!
Old 06-07-2016 | 11:11 AM
sterlingarcher's Avatar
sterlingarcher
Hey All,
My 2003 Cooper S (72k) has been burning oil like a champ—about a liter every 1,000 miles. Puff of smoke on startup indicates leaky valve stem seals. Also lots of oil in the intercooler indicates oil suckage. Burns much more oil when it's hot and when I redline it.
Any advice on next steps to identify any other problems and help prevent oil burning? Leak-down test? Heavier oil? Install a catch can? Complete teardown and rebuild of the engine?
BTW, I recently had a compression test done, it's at about 152 psi across all cylinders. Also it pulls strong, runs smooth.
Thanks!
Old 06-07-2016 | 11:34 AM
nkfry's Avatar
nkfry
Leak down test would be the next step, but if you're using that much oil chances are you're in for head work and/or rings. Catch cans don't stop oil consumption, they only catch oil particulate traveling through the PCV system.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old 06-07-2016 | 11:46 AM
sterlingarcher
Thanks! Can an engine have good compression while still burning oil? Would that indicate leaky valves more than rings?
Old 06-07-2016 | 11:48 AM
nkfry's Avatar
nkfry
Yes, you can still burn oil with good compression.
You need to do a leak down test, only then will you know what your biggest concern is.
Chances are the valve guide seals are dry and hard anyway, so a head refresh wouldn't hurt, but you have to diagnose the problem first.
Phone:586-792-6464
Old 06-07-2016 | 11:53 AM
sterlingarcher
Thanks, I'll get it done!
fjohn624
07-20-2016 09:30 PM
Autotragic
04-26-2016 06:22 PM
seamusnh
04-04-2016 04:46 PM
philmonty
03-25-2016 05:57 AM
kryall
03-21-2016 09:51 AM
