R50/53 Clutch fluid leaking from Clutch Slave Cylinder
Please help because the shop has no clue why this could be happening.
Things replaced relative to the problem: Dual mass to single mass valeo Conversion kit.
Clutch master and slave cylinder.
Pipe rubber end that goes into the slave cylinder. ( took it off a new pipe and replaced the rubber piece)
The shop would flush the system. I drive it for a week and the leak starts again and I loose my clutch peddle an it just falls through when the fluid all comes out of that area where the slave cylinder accepts the pipe.
First leak was where pipe comes into the slave cylinder, second leak was where the cylinder compresses. Shop said something broke there. and started to leak out from under the rubber.
The shop says the pressure is to high in the system. But Idk if they are right and they don't know how to fix it. I wanted to ask you guys before I take it to the dealer.
Last edited by edprok; 06-08-2016 at 10:56 AM. Reason: Shop updated where the second leak was.
hello ,
Whats year is your MINI ?
Rich.Wolfson
16
01-28-2020 02:58 AM
fixthedoor
04-15-2019 08:00 AM
