R50/53 Long valve cover bolt stripped
Hello,
One of the long bolts for my valve cover has the head of the bolt rounded so that the 8mm deep socket just spins and does not back the bolt out. I'm not really sure the best way to approach. I called the MINI dealership near me and they said that I would need a special set of bolt removal sockets, which apparently clamp down to the bolt head as it is being backed out. The guy I talked to said these sets are expensive and usually start at 10mm. Seeing as how I would need an 8mm deep size, I am hoping there is an alternative. Has anyone else has encountered this issue? How did you handle it?
Any help is greatly appreciated!
Those thing rust and then get really soft, I have removed them before with and extension and a really small bolt out kit. Small bolt out set size #2. But if the heads are really bad then its drill and tap out.
https://www.northamericanmotoring.co...on-2006-s.html
Hit them with a little grease once a year, what happens is moisture puddles on those bolt head locations and then rust the heads, over time they get pretty bad.
When I did my valve cover gaskets, I had the same issue. I just used a pair of vise grips to back it out, not that much torque on those bolts. I used a 7.5mm deep socket to put it back on. I would have used the 7.5mm to take it off, but I didn't know that I had one...lol
I had the same problem. The bolts are very pricey to replace! The short ones are about $17 apiece. I was able to hammer an older smaller socket onto the stripped bolt head to get mine out. The threads were shot on the studs so no double nutting here. I got by with vise grips and then bought a few new ones so I won't have to go throight that again.
Gabe3
02-25-2019 01:24 PM
mjgmcs1
Suspension
05-02-2007 11:23 AM
