R50/53 Rear Window Washer - 2005 MCS
Old 11-13-2004 | 03:50 PM
MCS05's Avatar
MCS05
I cannot figure out how to adjust the spray on my rear washer jet. It basically sprays the spoiler and trickles down. I have the new shop manual, but it only goes to 2004 and they appear to have changed the jet for 2005. I don't have a "slot" for a screwdriver adjustment - appears I just have the squirter itself, but it does have a flat spot on the bottom as if you could put some tool on it to adjust in and out ??? I have no idea - anyone out there figure this one out yet? Thanks!!
Old 11-13-2004 | 03:54 PM
jabrowntx's Avatar
jabrowntx
Great question, my rear washer sprays my sunroof
Old 11-13-2004 | 04:13 PM
JoeDentist's Avatar
JoeDentist
Get a large straight pin with a ball end. Put it in the spray jet, and aim the pin where you want it to go. Take the pin out.
Old 11-13-2004 | 04:26 PM
MCS05's Avatar
MCS05
Ok - not that I doubt you, but everything I have in writing says do not put anything sharp in the jet. I have adjusted older sprayers in the manner you describe, but I don't want to screw anything up on my Mini. Have you done this to adjust yours?
Old 11-13-2004 | 04:41 PM
lotsie's Avatar
lotsie
Now I'm not sure about the 05,but on my 03 the rear sprayer has what looks like something a fine sloted screwdriver would fit into,it will,turn it to the left a notch,and the washer should hit the window not the roof.Mine would spray the bonnet,and miss the rear window,from the factory
Old 11-14-2004 | 08:25 PM
mbabischkin's Avatar
mbabischkin
Look for a set screw back there... NEVER stick something in the nozzle on the MINI.
Old 11-14-2004 | 09:20 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
The front washer nozzles can be aimed using a small pin to 'swivel' the nozzles around (they have ball ends and move in their sockets), the rears on earlier models have a slot, the newer ones have another method I am unsure about (my documents only cover up to '04).
Old 11-17-2004 | 05:13 PM
Del's Avatar
Del
The 05 rears have the same 'swivel' nozzles. The pin does not harm the nozzle. I have just made the adjustment and all is fine.
Old 01-11-2005 | 12:06 PM
tattman23
Thanks all for a great thread (ps picked up '05 CR/B MCS last nite)
OK so I have one "issue" only, and it's with misaligned washer "jets" - we're not talking "slight" misalignment either, front AND rear . While it's far from a complete buzz-crusher, I still Must... Fix.... Now!
Well, being an experienced lurker and general pest, I had a feeling this information would be found around NAM someplace. What I didn't expect was to find the exact fix(es), complete with feedback and stuff, on the Very First Search .
Thanks y'all, and man is this car fun,
Tatt
iggi
17
09-02-2023 03:06 PM
07-16-2020 12:54 PM
mdutton11
14
10-26-2015 01:47 PM
FLYM1N1
08-16-2015 01:15 PM
bugeye1031
08-15-2015 08:14 AM
Quick Reply: R50/53 Rear Window Washer - 2005 MCS
