R50/53 Vents Blowing Hot Air Only
Hi - looking for some guidance. 2006 R53 with AC issues the last few weeks. Replaced the compressor about 3 years ago. Compressor engages but the air never gets cold. AC light stays solid. Have between 30-40 psi on low side while compressor is engaged and outside temp at 78 degrees. But the air never gets cold at all, even if I turn the AC off and have outside air only on when the air is cool. Any ideas? Thanks for your help!
Kelli
Kelli
Low refrigerant. Your high side should be in the range of 200 - 350 psi, depending on ambient temperature. See this chart to see what pressures you should be seeing at a given ambient temperature: http://rechargeac.com/how-to/ac-system-pressure-chart
The good thing is that since you have a proper manifold (I assume), you can now load R134a into your system by yourself. I find that Advance Auto has good prices on their cans - usually like $8 per 12oz. Our R53s only take 14oz of refrigerant, IIRC.
If you've never loaded refrigerant before, it's not that hard. Plenty of internet articles and youtube videos around to show you how. Just remember to always load into the low side!
If you have a leak, that is a different problem, however. But you won't know until you load some new refrigerant in there and see if it holds pressure.
cub4bearindiana
06-30-2016 06:11 AM
beemer2002
04-25-2012 09:15 AM
goaljnky
06-03-2008 07:00 PM
