R50/53 R53 Engine Questions
Old 09-27-2018 | 07:54 PM
BARTMAN0202's Avatar
BARTMAN0202
Does anybody know if the non-supercharged engine head will be a direct bolt on for a supercharged engine? I assume they would be compatible.
Old 09-27-2018 | 08:44 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
NO the valves are different so you will burn the exh valves if you put an R50 head on R53. You can replace the valves with the S valves and it will work, but I'd also do guides and seals if it's used.
https://www.waymotorworks.com/mini-c...valve-r53.html
minicooperlover22
12-15-2017 09:54 AM
Longjas
R55 :: Clubman Talk (2008+)
08-05-2013 08:16 AM
Black Boots
01-02-2010 12:51 PM
Blazermaniac
09-24-2007 01:17 PM
tinfro
11-23-2006 12:44 AM
Quick Reply: R50/53 R53 Engine Questions
