R50/53 Turn signal help
Turn signal help
I have a very unique problem with my turn signals. I say unique because I cannot find a thread that has been able to help. The right side of my turn signals work but not the left. None of the left turn signals work. All brake lights and reverse lights work fine but none of the turn signals on the left work. Not the back side or front. Please help! Closest solution I could find is the ECM needing replaced. I am new to minis and love it so far just want to figure this out.
Turn signal switch
Is this the switch that others are talking about in the steering column? I check the voltage for the turn signals at all three spots while it was “turned on” with no power going to it. It the switch would turn on the voltage to the turn signals when activated then you could be right.
More signal problems... No signals on left as well as low beam and break light.. Plea
gob15
10-14-2018 02:30 AM
Interior/Exterior Help to change turn signal color!!!
MalloryJade
02-07-2011 06:10 PM
Checkmate_2006
01-11-2011 05:43 PM
