R50/53 Lower control arm inner ball joint.
Can the lower control arm inner ball joint be removed without dropping the subframe? It looks to me like one of the bolts will interfere with the half shaft. Can anyone help? This is the ball joint that is connected to the subframe on that banana-shaped bracket.
You can. You will have to remove the CV axle from the hub an push to the side. I did it with mine a while back. Note, it helps to have a metric tap an die set when you remove the bolts. On mone they were rusted pretty bad. Once I treated the bolts with pb blaster an got them out. I clean the threads on the bolt an threads of the control arm. They went all the way in just by using my fingers. Then just torque them to spec
It really not hard if you have the rights tools.
Removing the CV axle is in the Bentley manual? I have a copy.
Im doing bearings and struts at the same time.
crazyworld
01-15-2014 05:38 PM
lx.josh
Suspension
01-07-2012 05:06 PM
JAB 67
01-23-2009 10:49 AM
