R50/53 tej98's 2005 Hyper Blue R53 Journal
#101
The following 4 users liked this post by tej98:
#102
Looks great! What adhesive did you use? That's on my list as well, but I need to find a donor. Mine had been destroyed my mice and a sunroof drain leak. Turns out the sunroof drain had detached all on its own. When I took the old one down, I zip tied the drain hoses on. There is a junk yard about a hundred miles away that has a couple Minis - taking the drive on Friday.
#103
https://www.walmart.com/ip/3M-Headli...RoCjC0QAvD_BwE
jcolletteiii (05-26-2020)
#104
Had a trip up to Deals Gap recently with family and had a great time. The car performed very well and could hold its own with modified E36 M3s and a Z3M, but I do think some more front negative camber is on order when I need front strut mounts . Some pics from the trip with the E36s mixed in:
A few weeks later I swapped out the old belt tensioner. It was long overdue and was likely the original unit. Also swapped the plugs out for a fresh set of NGK BKR7EQUP. Next up is the coil pack as I chase down an intermittent hesitation.
ssoliman (07-09-2020)
#105
tej,
Been to Deals gap 2-3 times starting about 15 years ago but on motorcycles, mostly vintage, and some not quire as vintage, ['93 K75S] Is the Tree of Shame still there? [at the motel with lots of broken M.C. parts nailed up]
Def. a fun road that tests your nerve as well as your skill.
robj
robj
#107
tej,
robj
robj
#108
#109
Been to the dragon twice, i know that stopping place at the bottom of the hill.
tej98 (07-09-2020)
#110
#111
#112
Yep! These are the standard halogen facelift lights. I'm not sure if they are an improvement functionality wise over pre-facelift but when I got the car the light output was not good. After adjusting them a bit they are perfect for my needs for now.
eimkeith (07-09-2020)
#114
#115
#116
What was supposed to be an easy swap turned into a little project. 2 of the 4 coil pack bolts were stripped on the valve cover side and just kept turning. Unfortunately this means the entire valve cover will need to be swapped out at some point but for now we were able to cut the bolt heads and pull the coil off. It still mounts up fine since 2 bolts work as they should. Ended up swapping my 7 year old Screamin' Demon coil with an fairly new OE Beru unit from the family beater R53. The hesitation seems to be gone now, and is also not present in the other car. My guess is that since my car is running a 15% pulley the extra boost under load makes it hard for the old demon coil to keep up but works just fine on a full stock car. Time will tell
#118
On the way to visit some family over Thanksgiving the starter died on the Mini about 300 miles from home. Luckily some employees at a restaurant I had stopped at for dinner were kind enough to push start the car. I double checked battery and alternator voltage before continuing the trip.
I finished the trip by push starting the car where necessary since I didn't want to take it apart away from home. I suspect either the starter or ignition switch is the culprit, but leaning towards the starter as I can clearly hear the starter relay clicking when the ignition is turned to start the car. Video for reference:
With finals going on I won't have time to swap the starter until the weekend, but I ordered a remanufactured Bosch unit from O'Reilly's during their Thanksgiving sale. It comes with a lifetime warranty and is ~$100 cheaper than most of the competitors as well. We'll see how the install goes
#119
https://youtu.be/2EwbJqC39Gs
tej98 (12-01-2020)
#120
Swapped the starter out last week in time for the local Caffeine and Octane show. The bottom bolt of the starter was very tight, likely just torqued down over time. My dad and I made a short video showing exactly how to swap it out for future reference, hopefully it helps someone!
Really the job wasn't too bad, I could probably do the job again in about 2 hours. The car has been running great and I've just been enjoying it through the holiday season. Happy motoring!
#121
Well, I listed the Mini up for sale in mid December and honestly did not expect any activity. But an enthusiast drove down from Charlotte and bought the car this past weekend! I just decided it was time for something a little different as I finish up college since I had knocked out all the projects that the Mini needed. I really enjoyed bringing the car back to its former glory and know the car went to a great home where it will be loved and cared for as it deserves. Not to worry, I'll be around with the family beater R53 for a while (no plans to sell that one any time soon).
Anyways, hope you enjoyed this thread! A few of the last photos I took of the car, I used our SLR camera for these:
#123
Thanks! I will, but having another R53 eases the feeling a bit
I’m thinking an E36 M3 or Z3 coupe. A special 90s BMW with a straight 6 will be nice. I’m in no rush, and will likely wait a few months to straighten out a few things. Maybe in that time the used car market will cool down a bit. E36 M3s that were 7-8k cars last year are now 12k! The same goes for really any enthusiast car right now.
ssoliman (01-14-2021)
SVTf
11
04-25-2015 09:29 AM
HB05MCS
08-29-2004 07:53 PM
