R50/53 rear hatch
Dear MINI friends,
The rear hatch door on my new MINI-S will not latch. It had been a sporadic problem but now is a permanent thing. As there is no authorized dealer in my home town, I have called MINI service depts in neighboring states but have found no solution. Any suggestions? thanks much, jim
on
1) duct tape
2) coat hanger
3) get it fixed by a far-away MINI dealer
4) beg and plead with your local BMW dealer to fix it
_________________
~Yucca Patrol~
2003 MCS, BRG/W on the truck to my dealer!
"Good judgement comes from experience, and experience comes from bad judgement."
2) coat hanger
_________________
~Yucca Patrol~
Jim this is a fairly common fault. It happened to me too. A forum search on "Boot Latch" will show how common the fault is.
There seem to be two solutions:
(1) The trunk latch is defective. Have it replaced under warranty. Until then use duct tape and/or coat hangers.
(2) Try to fix the problem yourself.
I took the latter approach. For me it happend the first day I had my car and I was playing with every possible widget. One of the advertised features is that if you hold the "wing" button on the key down for more than a few seconds, the hatch will pop open. So I held the button down, and after a few seconds the hatch unlatched with a click-click-click ratcheting sound. Then it wouldn't re-lock.
After muttering choice four-letter AnglkoSaxonisms used previously by Chaucer, and questioning the genus of the designer's parents, I decided to reverse engineer the fix. Try this:
(a) with your right-hand, lift up on the rubber-covered external latch release as if you were opening the boot.
(b) while doing (a), use your left-hand to press the shiny wing button on the key for several seconds until the latch chatters.
(c) Release the button on the key, then let loose of the rubber latch button. See if it works OK now.
I think that, unless you are one of the unlucky ones with a defective mechanism, the latch will again work correctly. Apparently, the internal solenoid can get out of synch with the electronic signal originating in the key, But that's only a guess.
Since it happened to me, I have never tried to reproduce the fault by using the "open boot from a distance" "feature" for fear I WILL become one of the unfortunate folks who actually ended up with a broken latch.
Hope this helped -- Tom
tom, thankyou so much for taking the time to respond to my question.. I noticed my message was posted at 4:44 am. Must be something wrong with the clock. I may lose sleep over many things but it's not the boot hatch. Anyway, I tried your method with no luck. In the beginning, I suspected an out of synch problem and did just what you recommended and it worked at times.. but not now. Looks like it will need to go to the shop. keep on motorin' jim :smile:
no big deal.....that's the first rattle I had in my MCS....warranty fix, then had a sunroof rattle, also warranty fix, then had dash rattle, also warranty fix, then seat frame broke, also warranty fix...all working fine now....add defective runflat, malfuntioning supercharger, blown air compressor....all warranty fixes....hopefully they are correcting the early 02 build problems on the new deliveries....good luck !
silence2-38554
08-29-2015 08:10 AM
08-07-2015 05:55 AM
