Alternator problems on my 06 mini cooper s
I recently bought a 06 mini cooper s with a bad alternator, I changed out the altenator myself and it seemed to be working as I had to boost the car to move it then after I drove around for a bit it was starting good and my batterie light was off. But a few days later the light is on and its not charging. I used a multi meter to test the voltage while the car is running and it isnt charging even at high rpm. I also hooked up leads to the alternator itself while the car was running and I only got the batterie voltage back which leads me to belive the alternator is faulty but I want to be sure before I drop another 300 on a new alternator.
Looks like a bad alternator, sux having to change out for another unit, but didn't you have a warranty for the one you just put in?
gumbedamit (07-24-2019)
I agreed with you on that. What I said is if the battery is dead/bad, the alternator with still have an output.
I checked the batterie and it is good under load, i have checked one of the ground straps, but my thought is that if there was a bad ground that was only affecting the operation of the alternator i wouldnt be getting the batterie voltage when i hooked up directly too the alternator(not an electrician mechanic tho). I guess ill have to suck it up and take her apart again for that danm burried alternator.
Hopefully you have a Warranty on the alternator...
Nadia5750
02-14-2013 05:09 PM
dsher10426
11-16-2009 12:06 PM
owl
04-08-2009 05:06 PM
