R50/53 Suggests for fix action... Coolant in oil
I attempted to post this two days ago but something failed.
i was overheating and got and stayed hot, I found a cracked expansion tank and replaced it. Before I found the coolant in the oil I was starting to use fluid on short trips and thought it was from the crack in the tank.
So I replaced and still have pressure on the coolant after a night to cool,. I may going to replace the thermostat but looking for suggestions while I have the car apart to look for.
Will look at the oil cooler as possible point that the leak is..
Other other suggestions would be great.
