R50/53 R50 No Start- please help
Facts about my R50
- Purchased about 3 years ago with 95.5K miles
- Currently 99k miles
- Coil pack & spark plugs replaced about 1.5 years ago
- Always driven on premium gas
About a month ago on a Friday I drove it to work which I hardly ever do. I had no problems in the morning but at the end of the day (it rained a lot all day) the car won't start.
I tried to bump start it but that didn't work. I ended up having it towed back home.
At home I took the following steps to try to solve the no start issue:
- replaced the battery (it was due anyway), no start
- replaced the ignition switch, no start
- the fuel tank was not empty but pretty low
- replaced the fuel pump fuse and relay
It started but after one day the same issue came back. I couldn't get it to start.
I then did the following:
- I filled up the fuel tank
- I replaced the fuel filter, no start
- I replaced the fuel pump, no start
Please help. Thanks.
Have you tried jump starting it with another car? I would try that first. That will eliminate a bad battery if it still doesn't start. Then, check the fuel pressure (when turning over) using the Schrader valve on the fuel rail. Be sure and use a rag because if it's working it will shoot fuel all over. If no fuel, then your issue is in the fuel delivery system, i.e., pump.
I then checked the Schrader valve and there is no pressure. I also checked one of the spark plugs and they are completely dry. Shouldn't you see or smell some gas after a starting attempt.
So it must be the fuel pump. When turning the key I do hear a priming sound (I think).
Still no luck starting my car.
Could it be the Carquest filter I used? There is absolutely no pressure on the line.
I found this thread but it’s not that easy for me to pick up a genuine mini filter. https://www.northamericanmotoring.co...n-t-start.html
When you changed the fuel filter did you ensure that the pump top was fully seated (make sure it clicks in place)? If it's not secure your car will not start. I did the same thing the first time I changed my filter. I thought the top was seated but it was not. When I fixed that problem, the car started right up.
Just a followup: After replacement, my pump was audibly priming but the car would still not start since the pump lid was not fully seated. It took me three tries before it finally sealed. It takes a ton of downward pressure in order to turn it all the way. After that, the car started immediately.
