R50/53 Bargain Mini - One thing leads to another.
What's that song, "one thing leads to another"?
Engine pretty much done. Checked ball joints, [sloppy] 155K miles so might as well do struts, strut bearings and hubs to go with the new axles. Ball joints, Poly LCA bushings, and what the heck, poly sway bar bushing and links.
So here we are... But the wheel supports and caliper brackets are bead blasted and painted pretty so that's something. And all that cost was a can of paint!
robj
robj
Soul,
Thanks. I forgot about the ABS sensors, mine were stuck as well and had to get new ones.
I usually know what I'm going to do the next day and give everything a shot of BP Blaster before I leave for the night which really reduces the bolt snapping issue.
I did break one of the 12mm [10 mm?] bolts that hold the lower strut to the steering knuckle housing. My impact was just bouncing so I heated up the threaded side. [Heat before Hammer!]
Put the breaker bar on it and it did just what it's name implies, broke the bolt off right at the head!
When getting the bolt out, [no fun] I realized the bolt was actually seized on the non-threaded side, not at the threads. Never suspected that.
Even after 50 some years of messing with cars I'm not sure I've ever seen that happen.
Live and learn.
robj
Live and learn.
robj
R50/53 Broken Strut Pinch Bolt
ericbryant24
55
09-30-2024 02:10 PM
