R50/53 Inpa
I got my DLC cable and BMW software from here several years ago. If I remember correctly, it was a very long and confusing setup.
i was thinking there might be a thread here where the process is summarized?
But if not, I’ll try and google it and see where that goes. I think the software is available online or with the cables that I bought. Need to verify the version and the “daten”? files specific to r53 mini.
the search continues. Anyone have a bone they can throw me on this...any info is much appreciated
I used these threads as a starting point when I did it
https://www.northamericanmotoring.co...beginners.html
https://www.northamericanmotoring.co...onal-info.html
I also had to download the software from a BMW site. Can't recall where.
Here are two threads that I've saved for my own future purposes:
https://www.northamericanmotoring.co...ml#post4450602
http://bmwcoders.com/forum/bmw-gt1-o...tool-winkfp-1/
The critical thing is to find GTECKO's package. It's pretty easy to use out of the box. Here's his thread where he posted the package.
The CLICK HERE is the important part. Get that file, follow the instructions to the letter, and you should be able to connect. The most common failure is to not have a cable that connects pins 7 and 8. I bought one from a company called JahyShow off Amazon and soldered a short jumper wire between the pins.
https://ncs-expert.com/purchase
This one you have to pay for but it includes NCS and INPA plus bonus ones and all datens. There is a sale on at the moment. I use this and it was plug and play with easy instructions. I am not affiliated with this company. Download links are almost instant and saved in the store for a few days/emailed to you.
Good luck. I have tried the GTECKO package and others and they are a nightmare to set up.
Here you are a INPA version, no need special install,just copy and paste all 4 folders in C drive.For Inpa diag sw,just open INPA folder,than BIN folder and execute Inpa .exe file.
Install INPA cable, use driver send by seller ans install instructions.
https://mega.nz/#!4B9SlQJA!yCiZPHhhT...DqY0y2WS9LZ31o
Try different profiles, must work.Here a small video how to use NCSExpert and NCS Dummy to recode EMS and BC.
Got it working this weekend, gents.
Followed the instructions here (includes downloads): https://www.bimmerforums.com/forum/s...xperimentation
Cable:
I used Windows 7 but not sure that matters.
Last on the cable put the switch all the way to the right (I'll upload a pic)
Cable:
had a look. Thank you, sevin.
Nevermind, I was able to get it working, didn't run the dataload exe. Must run in WIndows Compatibility Mode if you are running in WIndows 10
ssoliman (02-16-2020)
I installed the GTECKO package and it seems some of the R50 (and R53) files are missing. I copied the LADEN.BAT file from the R56 Datens, edited to R50 and ran that but still no chassis options showed up so I edited the INPA.INI. Then it says it can't find R50.ENG. Any help? Tried several other packages as well.
Hey guys.. what's it called when you turn off the car and for like 20min the front little lights in the bumper and the lights on the fenders and fender trim stay lit ? I've always wanted to deactivate that and my daytime running lights which I see is an obvious option. I know it doesn't draw much current on those lights as they are barely lit, can only see them in almost pitch black and I'm sure it's a safety feature but I live where everywhere is lit by streetlights , even the freeway and I garage my car
To use CD or not to use CD?
Cable: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
WhoHasGotTheBlueS (09-16-2021)
