R50/53 timing an R53
Old 11-07-2019 | 02:15 PM
Bill Tsoukanis's Avatar
Bill Tsoukanis
timing an R53
Hello
I have searched the FAQ and sticky threads but no info.
From what i have gathered searching different threads when using the timing tool to lock the cam so the timing there is correct, the pistons should all be at mid level (2 positions).
The question is should the first piston be going up or down?
Old 11-07-2019 | 10:07 PM
ssoliman's Avatar
ssoliman
Saw a few videos on YouTube...but i don’t specifically remember your question being addressed.
might search there if you don’t get an answer here
also it’s in Bentley
Old 11-08-2019 | 03:24 AM
1qwkmini's Avatar
1qwkmini
The only true way to do it is pull the oilpump/timing cover and use the marked links on the chain and the timing marks on the crank pulley and the cam gear. Piston direction is not a factor if you follow the proper method.
Menic
11
01-25-2020 09:07 AM
Busyb187
09-06-2019 05:22 AM
99mini
04-10-2018 04:32 PM
stevepb05s
04-16-2013 09:34 AM
Rholt
Classic Mini Talk
08-11-2012 04:28 PM
Quick Reply: R50/53 timing an R53
