R50/53 How do I remove gas pedal 2003 R53
I need to remove the gas pedal but can't seem to figure it out. All the information online says there should be an allen or torx screw in the front but my pedal don't have that. Did the early model R53 have a different pedal? Any help would be awesome! Thanks.
Don't do that, you will break it!!!
Push down on the tab circled in blue...on the brake side of the pedal... and pull the assembly towards the brake pedal. Be careful pushing down on the tab and likely you will break it no mater what you do..they become very brittle with age. You will find the tab in the slot circled in red.
2004 R53 Gas pedal Assy. Replace
R53. 2004 S ..... I have a friend in the wrecking yard business who handed me a nice LIKE NEW gas pedal assy. Only issue is the plug is not right. Is this something I can safely rewire? I have the pigtail from the newer pedal assy....it has different things/tabs keeping it from plugging right in. It's apparent it's from a newer Mini.....can I splice or is that asking for trouble? TIA
Spoiler
ssoliman (12-30-2019)
This worked.
Push down on the tab circled in blue...on the brake side of the pedal... and pull the assembly towards the brake pedal. Be careful pushing down on the tab and likely you will brake it no mater what you do..they become very brittle with age. You will find the tab in the slot circled in red.
ECSTuning (01-29-2020)
Yep, also if you have crud down there its a good time to clean out dirt around the mount and carpet, thats what i did when i swapped mine out for the stainless pedal upgrade.
