R50/53 Rant
Rant
I just had to rant a little. I was super excited to have my R53 back together again. It runs super smooth, sounds amazing with the full Milltek resonated exhaust. It’s definitely a different car with the 15% SC pulley, 2% OD pulley, Detroit tuned bypass valve, and the DDMworks air box. The supercharger wine is very noticeable. I replaced lots of parts and gaskets, but those are the hp gain parts. The sad thing is I have to take it all back apart, because there is a coolant leak. @#$*! It looks like it’s coming from the water pump area. The water pump didn’t leak before, but since it had 111k and I suspected it was the original, I replaced it. I slid the radiator out some on long bolts and brought the engine up to temp. It’s defiantly coming from that area, but I can’t see where so I can’t pinpoint exactly where. Is there a way to determine if it’s a gasket or hose leak or is it just a guessing game from here that I just take it apart, reassemble and hope for the best?
robj (12-27-2019)
Macsplinter (12-19-2019)
I do have a question though, if it is leaking from the flange or the water pump O ring, wouldn't it leak as soon as the car is started? It doesn't start leaking until the car is warmed up, so at first I thought it was coming from the thermostat housing, but the drizzle flow is coming from below the water pump that I can see once the radiator is pulled out far enough to see while running.
Does the tip bend on that one? We have a scope at work we can bend the tip 45 degrees in a 360 pattern. I wish I could take it home to use 😕. I haven’t had time to work on it yet, but I’m still thinking about the leak. It doesn’t start leaking until the engine is up to temp and the thermostat opens. Does this give me a clue as to if it’s from the flange or thermostat housing?
theimage
02-05-2018 07:13 AM
