R50/53 $500 bargin Mini-Airbag Light
After 6 months work I have been driving the $550 Bargain Mini since Saturday and have about 250 miles so far. Too much fun, sounds terrific and hasn't missed a beat.
Night before last the air bag light came on, out of the blue. checked the seat connections, didn't find anything.
I have the Schawaben scan tool and founds codes for the airbag. Started doing research and found this discussion;
https://www.northamericanmotoring.co...g-light-2.html
I found a post that said;
"The Schwaben will clear airbag lights"
https://www.ecstuning.com/b-schwaben...020sch01a~scf/
I Couldn't make it happen. Any hints?
I think I found the same code in each category
Codes found in each category
Message I got when trying to delete.
Is it actually possible to delete these codes with the Schwaben? If so anyone have the steps so that even a dummy can understand?
robj
robj
I did check the connection under the seat so I guess the next thing is to take the steering wheel off and check the connections there?
Anything else to check for an actual problem?
I just read so many posts where the light showed up out of the blue with no actual issue. I put my dog in the passenger side, then saw the light but the codes say "drivers side".
I was thinking to try to clear the light and see if it comes back.
Carwash,
And yes, I do have a sunroof. Does that affect anything with the airbag light? Please tell me it doesn't, even Mini can't be that weird...
Thanks,
rob
Yes it will do it, i have done it. If you have a fault or it has trouble with communication to the module due to a problem with the module or a low due to a dead battery or weak connection to the ecu. Also a connection or wire between the airbag and system might be damaged. Sometimes low voltage to units can make this happen.
