R50/53 Hard brake line tube nut sizing.
So, I know the pre-flared piping has the tube nuts already, but I am creating my own and so those are what I am needing.
Is there a specific part number for these nuts which press the bubble into the intermediate housings (parts 34326757285 and 34326757282)?
They look like they would be generic fittings, but I want to make sure I have the correct sizes and whatnot. People at one shop tell me one thing then something else at another. I even went by a local BMW/MINI specialty shop and they were kinda stumped. So I'm turning to comrades! Many thanks!
Looks like M12x1 tube nuts are the size to mate into Part #14 you reference. It also seems M10x1 is the size you'd need to mate into the (flexible) brake hose fitting if that's the line you're working on.
https://www.realoem.com/bmw/enUS/sho...diagId=34_1396
https://www.amazon.com/Steel-Tube-Nuts-Metric-thread/dp/B07BMYZ245/ref=pd_sbs_263_3/138-0038303-1624973?_encoding=UTF8&pd_rd_i=B07BMYZ245&pd_rd_r=b5fdcb23-7514-4613-a6c3-2beeb23413a0&pd_rd_w=4S5jN&pd_rd_wg=A9Jen&pf_rd_p=bdc67ba8-ab69-42ee-b8d8-8f5336b36a83&pf_rd_r=3H390YYZ25ED8AXNMF4A&psc=1&refRID=3H390YYZ25ED8AXNMF4A#customerReviews
ssoliman (07-24-2020)
Brandin Sharp (08-05-2020)
on the other line at the join was M10x1 and the rear side on passenger side didn’t have time to remove it but I will guess will be another M10x1.
tomorrow I will let you know when I remove the rest of that line.
mine was so rusted that it just broke while removing it
BMW and Mini used M10 fittings in most cases. Some are M12 - we think that is for assembly. These are all DIN flares. If you go by your vin in realoem.com, you will see cryptic notes next to some of the lines like M10/M12 1366 - a line with an M10 and an M12 fitting that is 1366 millimeters long…. If you go to American Grease Stick - they sell Cuprinol lines - a copper/nickel alloy - much easier to work with.
Be careful- you need to practice, and check your work. Your life and others depend on this.
micromini234
06-06-2013 02:39 PM
