R50/53 Hello! Newbie W/ R53's
Hi There -
I recently acquired a 2004 Mini Cooper S. I got it to save it. Poor thing is leaking Coolant and Oil pretty bad. She drives fine and all that - albeit she needs a few things here and there. I have been researching things a bit, and apparently these leaks are known Mini Maladies. I work on cars and will be able to fix most if not everything she might need. I am here to learn as much as I can and hopefully contribute where I can as well.
Current situation is I also have a 2006 Mini Cooper S, which is actually a DINAN S Mini. My initial plan was to restore this DINAN S, however my new thought is to take all the goodies from the DINAN S and just put them on the 2004 Cooper. The 2004 is in much better shape and actually runs and drives. The DINAN S has a bad engine - seems to be the low / bottom end. Also, the interior is trashed, etc.
They both have the R53 Engine right and are essentially the same car, so I should be able to transfer all the parts over, like:
Coilover
Sway Bar
DINAN Intake
DINAN Head
DINAN Brakes
Wheels
That kind of stuff. Then also fix the leaks and issues on the 2004 and make her a fun car.
Any and all input are most welcome, hope to be come an active member on here.
Cheers!
Coilover
Sway Bar
DINAN Intake
DINAN Head
DINAN Brakes
Wheels
Cheers!
The following 3 users liked this post by PhoenixMini:
Yup! I fold car mirrors out of habit and living in cities
Welcome! And nice project
To answer your question about compatibility, yes many of the parts will be the same between the two. The things you list should fit. The SC rotor lobes on the 06 have a better coating, so maybe check out the condition and bring that over as well. Also keep in mind the tune on your 06 was different from the 04 already from the factory, and likely even further away from the 04 after dinan got to it.
Here’s a great article about the difference between Early years and facelift years:
http://www.motoringfile.com/mini-r50r53-buyers-guide/
That link was great! I had seen it before a long long time ago, I really appreciate you posting it. Interestingly enough, it caused a moment of pause as to the prudence of my idea as the 2006 MY seems to be the better of the two cars. My thought behind the project is that the 2006 - while a Bona Fide DINAN S - has a number of issues to be dealt with.
The engine's bottom end is bad. Rattles worse than a caterpillar diesel so will need to be replaced OR rebuilt. Also, the car's interior has been torn apart by the PO, the sound system was ripped out and it has a broken windshield. In addition to that, the paint is pretty well faded. My initial thought had been to acquire a donor car with a running R53 and swap out the Heads from the 2006 and then use the donor car to rebuild it and keep it as an Original DINAN S with VIN number and DINAN Serial Number. Other than the issues, the 2006 comes with the wheels, a coil over kit already installed, what might be DINAN BREMBO Brakes (They look legit and were part of the package), a new drive axle was included. Also, all the missing hood trim pieces are actually inside the car. I also got a new After market sway bar with it. In addition, it has a relatively new light weight clutch and flywheel (To be confirmed).
I now wonder if that original idea is the way to go? Oh... another reason I got the Red one is that it has a Black Interior which can swapped into the Yellow 2006 as it is in much, much better condition.
If I go with the current plan, I will strip the Yellow Wasp of:
Brakes
Suspension
Sway Bar
DINAN Intake
DINAN Intercooler (I believe it has one)
DINAN Pulley
DINAN Valve Head
The Clutch Set
Possibly Shorter Ration Transmission
Possibly LSD (If it has one and it fits)
Then whatever else is transferable. However, as I learn more about the Mini, I wonder if that's the way to go? Oh Boy!
Quick update to this thread. The decision is firm that the Yellow DINAN S will be the donor car here and I should start taking it apart this week - hopefully. I have already swapped the wheels over. Next will be things like suspension, intake, brakes, etc. Seems that DINAN Never did head work on these cars, so that may be staying in place unless I learn something different.
The 2006 on the Left and the 2004 on the Right.
The wheels properly installed on the 2004.
Someone added a valved extra pipe I guess for sound effect. Might be deleting that eventually.
Adjustable rear control arms on the 2006
Raceland Coil Overs - Nothing too fancy or special from what I can tell.
So, I am forging ahead with my decision to use the Yellow DINAN MCS as a donor car. As I start taking it apart, I realize it is not "all that" as far as being a DINAN. So far, all I see are the Intake and the Exhaust and possibly the tune.
I got to check out the main pulley, and it's an OEM Piece, seems kinda. I suspect the DINAN one was removed prior to sale as the build sheet shows it should have one. I am waiting to check on the SC Pulley, but I doubt its a DINAN either. C'est la vie.
As some know, the poor Red 04 MCS had her passenger side glass broken last week. So, first order of work was to harvest the window from the Yellow Wasp as well as the regulator. Dear Lord! I really want to meet some manufacturing engineers to ask what the heck goes through their minds when they build and design cars. The regulator is a PITA! Thankfully, I was able to make the swap happen.
Next was the Steering Wheel, that was much easier and straight forward. Pretty much same set up as a BMW of that era. Airbags, connector, etc.
With that done, I am slowly starting to take the Yellow Wasp apart. First make me feel good move today was to remove the front left brake / caliper and the Coil Over strut. Gotta tell ya, I am kinda glad I am wrenching on these cars. I am find stuff that just not done properly by previous owners on both cars. Inexperience, carelessness... or both? Ugh. On the front strut, the spring is not seated properly on the upper pad / mount. Gonna have to correct that. Might just replace the shock mounts while I'm at it.... Hmmm?
I'll update as work progresses..... Cheers!
And now... .pictures:
Donor and Recipient, side by side
Regulator from Donot, PITA!
Going in - Door Panel Out!
Regular has been swapped, broken glass and old regulator are gone.
Replacement Glass is in - from the donor as well.
Glass all installed.
Yay!
Old Steering wheel coming out. First the airbag
Then the wheel itself.
Old Wheel Out! Anyone need / want this?
Old New Wheel going in. Bolting it down
Wheel installed.
Here is the pulley on the car. Notice new looking bolt
Time to take this assembly off....
There we go!
Front strut assembly
Spring not seated properly - Ugh!
Yay!
Wheel installed.
There we go!
Tragesaurusrex (09-13-2020)
Got a bit more work done on the Yellow Wasp today. I was also able to crawl under it to check a few things out. I found of course the DINAN muffler, however that second pipe was added to the exhaust as a side piece. Not sure I want to keep it yet.
Also, I did find an A/M Pulley on the Supercharger - doesn't say DINAN though. And it seems to say 13% or is that 15%? I was able to pull the front bumper off today as well as remove the strut assembly on the driver's side. This one seems to be in good order - that's good!
I came across an interesting Coil Pack. Wonder if anyone has any idea about it. It's called Screamin Demon.
Front Bumper cover is off!
Front Bumper and Support are off. Seems the bumper has to come off for any serious work on this car
This is the pulley on the SC. Any info, thoughts and such would be appreciated.
I got this new Sway Bar with the car. Not sure what brand - it is adjustable though. Need to measure the diameter
Adjustability - similar to DINAN Sway bars
This is the exhaust set up. The wiring (loooong harness) runs under the car.
The end piece with a valve.
Clearer view of the adjustable rear arm.
The DINAN Muffler.
The Coil Pack from the car - Any ideas? Can I use Stock Plugs with this? Anyone ever used this?
The driver's side assembly
The DINAN Muffler.
The pulley is an Alta 15%, you will need to run a cooler plug than stock and I would assume the car is setup with the cooler plugs now. My guess on the anti-sway bar is maybe Whiteline?
It is sad that the 06 is toast, but at least you can part out the car to get funds for the other. Good luck with the build!
Steve
Steve
Steve
Steve
Sad about the 2006, but this truly was the best decision I could make. I am actually swapping over a bunch of parts to the 2004 and then the rest is available for the community if the parts can be of use / help where possible.
All they did was add this extra piping just before the Muffler with a Y junction / weld. I honestly couldn't tell you how well it flows exhaust to the muffler side when closed. The valve it literally at the tip, so I'd say it works kinda like a helmholz chamer of sorts ... maybe? This is in the fact that exhaust will flow into the closed off portion first and then I get just back up from there. Actually not sure how good that is. Maybe it will create some phantom back pressure at low to mid range revs?
Did a bit of work on Red Sonja today. I installed the Raceland Coilovers from the Yellow Wasp on the car - fronts only today. I will be doing the rears as well, just need to ready myself as I will also be installing the new Adjustable Rear Sway Bar.
I did practice on the rear sway bar today on the Yellow Wasp, able to get it out - but I haven't figured out how to get the bloody subframe bolted back up. Till that is figured out, I'll hold of on installing the new rear sway bar.
While replacing the front shocks, I sadly noticed that the car will be needing a new Driver's Side Axle Assembly. Same as the Yellow one actually. I wonder if this is a MINI R53 issue? While I was in there, I also replaced the front brake rotors.
ssoliman (09-01-2020)
Thank You! I actually got a spare axle with the Yellow Wasp when I acquired. Just wonder how difficult / involved it is to replace them.
I got some work done on Red Sonja the last few days. I mentioned I got the front Struts swapped with the donor units from the Yellow Wasp. I was actually able to take her for a test run down the coast and up through the local canyons. What a difference in ride and performance.
I have now swapped out the rear shock assemblies as well with the Raceland Coilover set. I think I may raise her up a little bit after my test drive. Again, the car is a completely different car to drive now. Very planted, stable and direction change is almost intuitive.
I was also able to remove the Rear Adjustable Control Arms. But wasn't able to install them right away. It's another of those stupid design quirks with this car. The parking brake cable was in the way of the Hub Assembly bolt - Ugh! Also.... I noticed that the rear hub assemblies on the 2006 are different. They are adjustable as opposed to the 2004. The more I think about it, I'm now so sure about using the Adjustable control arms on the 2004 since I can't adjust the mount angle at the base of the hub assembly.
First test drive with just the front coilover assemblies installed.
This couple joined me for lunch
They brought a few friends.....LOL!
Rear assembly about to come out
Assembly out. Out with the old, and in with the ...ummm.... not so old?
Ready for the coilover assembly
Assembly in
Bolted up and ready to roll
This always cracks me up! LOL!!!!
Driver's in and bolted up
The Adjustable Rear Control Arms
Assembly in
ssoliman (09-02-2020)
Not something I thought about, not sure it's something I want to do. Can't really vouch for the entire donor subframe. Are there any benefits to the 2006 vs. the 2004? The rear sway bar is gonna take a moment as I need to acquire new mounting hardware for the 20+mm bar. The stock stuff won't fit.
Not sure if it’s worth it unless your 2004 has problems with the subframe as I think everything’s the same on those two cars except for the trailing arms.
After 2003 the front brackets for the rear trailing arms were updated to improve the geometry. For the 2005 facelift, camber adjusters were added to allow a small range of adjustment. Since you already have adjustable control arms, these adjusters aren’t needed.
A popular mod to look into would be upgrading to R56 aluminum trailing arms.
ssoliman (09-03-2020)
