R50/53 Coolant Hose Question
My 2006 R53 w/ Automatic and has a coolant hose failing that comes off the backside of the hard water pipe and connects to a T-Splitter. Based on my research I have two options 1) purchase a new 8-way hose P/N: 17127541095 as it is not sold individually or 2) a DIY solution that replaces the failing section of the heater hose or 3) P/N: 17127518574 #24 in below chart lists this on realOEM but for M/T does not specifically call for A/T - don't know if same part
The hard part is that this hose piece is a reducing 90-degree fitting. Before removing the hose and measuring myself I was hoping someone might have O/D of the hard water pipe and the O/D of the T-splitter (shown in image) to size the hose right.
One company I found does sell reducing elbows so there is some hope that doesn't run $110+ for one hose: https://www.pegasusautoracing.com/ke...ywordButton=Go
Thank you!
O/D of pipe on the hard water pipe needed
#6 shows the hose that is failing (#6 is a hose clamp part number)
#24 might be the part but not listed for A/T
Thank you!
htroberts
08-03-2019 01:24 PM
Lex2008
01-22-2019 05:12 AM
