R50/53 SRS Code 81
Old 07-05-2021 | 07:14 PM
SkiahMutt's Avatar
SkiahMutt
SRS Code 81
Hello NAM! I recently purchased my second R53, and so far I'm loving it. I'm chasing a couple warning lights down at the moment. One is a evap leak, getting it smoked next week to try and find it, so I'm not too worried about that one yet.
The issue I'd like a little help with from NAM is the SRS light. I'm showing a code 81 on my scanner. I'm not sure where this sensor is located. I've pulled the trim off the interior, and the sensor at the base of the left hand B-pillar is in place and appears to be in good condition. Is there another sensor located elsewhere? One in the door? Or is the sensor in the base of the B-pillar the only side impact sensor?
Old 07-06-2021 | 10:23 AM
mrbean's Avatar
mrbean
There's another set of sensors inside the doors. Interestingly, they're pressure sensors. When the door gets smashed in quickly there's a pressure wave of air that's detected by these sensors.
Also, there's no way you can tell a sensor is good just by looking at it so I wouldn't rule out the one by the B-pillar. You'll have to test them.
Old 07-06-2021 | 10:29 AM
SkiahMutt's Avatar
SkiahMutt
I'll check into the door sensors.
What's the test procedure for them?
Old 07-06-2021 | 10:35 AM
mrbean's Avatar
mrbean
Try swapping the sensor left-to-right and see if the code changes.
SkiahMutt (07-13-2021)
Old 07-13-2021 | 02:09 PM
SkiahMutt's Avatar
SkiahMutt
Well, I decided to try swapping the door sensors around today, while I was replacing my window regulator, and I ran into a small issue: I can't seem to find them. I followed the wiring from the door connector to each termination, but I didn't find a sensor at the end of any of them... Build date 07/05/04, what are the odds I don't have those sensors and instead only the sensors under the B-pillars?
Old 07-14-2021 | 07:33 AM
adriancl's Avatar
adriancl
Behind left side rear seat, S71 part.
Old 07-14-2021 | 07:59 AM
SkiahMutt's Avatar
SkiahMutt
Wow, that's an excellent resource, thank you! I'll swap those sensors today and see if the problem follows the sensor.
Just to verify, it's possible that I don't have the door pressure sensors that were mentioned by another poster above?
Old 07-28-2021 | 09:06 AM
SkiahMutt's Avatar
SkiahMutt
Bumping this. Replaced the left hand sensor under the B-pillar with a new sensor, checked wiring and connector, still having the issue.
Can anyone give me more information on the door pressure sensor?
Old 07-31-2021 | 09:34 AM
SkiahMutt's Avatar
SkiahMutt
So I've located this page in the service manual. Problem is, I don't appear to have the part labeled "B78" or "B14143".
Where it gets weirder, though, is the I don't have those sensors on EITHER front door(even though I'm only throwing a code for the driver's side), and I don't appear to have any wiring that could go to them. Like, there's no unplugged connectors or cut wires in the door loom that I can find. Somebody help me out here, I'm losing my mind.
Old 07-31-2021 | 10:13 AM
SkiahMutt's Avatar
SkiahMutt
I'm dumb. My car is apparently MRS4, not MRS5, so I haven't got door pressure sensors, if I'm understanding this correctly. So that leads me back to the sensor under the B-pillar, or, more likely, the wiring, since swapping the sensor didn't do anything.
Old 07-31-2021 | 01:42 PM
adriancl's Avatar
adriancl
Can use wiring from this doc, page 132.
File Type: rar
Old 08-01-2021 | 06:21 PM
SkiahMutt's Avatar
SkiahMutt
I keep getting errors trying to extract that, any chance you've got a non-compressed version?
Old 08-03-2021 | 01:25 AM
adriancl's Avatar
adriancl
try this
https://mega.nz/file/BM8EhaTK#g6tT0B...aQuexnQB7XVco8
J Free
02-15-2022 12:15 PM
alexs3d2
09-06-2014 09:59 AM
jerryt
01-18-2014 11:30 AM
Josh Rogers
07-08-2013 12:18 PM
jrprich
09-06-2008 06:46 PM
Quick Reply: R50/53 SRS Code 81
