R50/53 Arduino O2 sensor Signal Modifier
Hi everyone! I have been working on a project for a little while now. My r53 Mini Cooper S is currently exempt from emissions in the state I'm located. I ended up removing my cat a while back as it was failing and causing issues. This of course led to a CEL. I tried using a defouler with different lengths and bungs to try and get rid of the CEL to no success. I also tried using the capacitor+resistor trick which caused a different code, (circuit Malfunction). Over the past few weeks I have been studying how the O2 emission system works, and how it self checks to confirm proper O2 operation and Cat operation. I began working on some Arduino software to trick the ecu, just so I could get rid of the emission codes, so I could monitor my light for other issues that may pop up. After a couple days, i got the software working, wired it up to my Mini, and the codes are gone. The cool thing about the software is it has adjustable parameters, so it can be dialed in to work on different vehicles. I was thinking about selling this software for the DIYers out there that are not required to pass emissions, but want to get rid of the Emissions codes that trigger the CEL constantly. Would anyone be interested in something like this? I have written up a full set of instructions on how to set it up as well. Please give me any input or ask questions! Thanks!
P.S the reason I put this in the r53 section, is I know that this will work on r53's, I cannot confirm that it will work on other models, but in theory, this software SHOULD work on any vehicle.
ssoliman (10-25-2021)
Cool that you figured out a solution; but you're in dangerous territory.
https://www.epa.gov/sites/default/fi...s-enfalert.pdf
Well in my state that i live in, the rule is that if your vehicle is over 15 years old you no longer have to pass emission testing. maybe im not "exempt" but atleast in my state passing the emission testing is not required. Ive passed 3 inspections now with a CEL for a rear o2 sensor code.
Thats exactly what i was thinking! i was going to add a disclaimer to the software for anyone that used it, would have to agree to the rules that, it is either for off road use only, or your vehicle was not required to pass emissions in your state. and if they were to use it to pass emissions, that would be on them. ill still think about it. I may make it open source so people can access it if they want. But if its a big risk i dont think its worth it for me!
ssoliman (10-26-2021)
ijourneaux
06-20-2019 05:24 PM
mauk517
06-12-2019 05:38 AM
