R50/53 squeal sound
squeal sound
For the better part of a year, I'm hearing a squeal when I first move forward in first gear. It only happens when the car (2003 hatchback with 145,000 mi) has been sitting over night or longer. Can't tell if it's a clutch sound or from a belt. Once I've driven it for a few minutes (5 or so), it doesn't happen again as I travel along, until it sits again for a while. Any thoughts? George
I have the same issue. It usually happens in colder weather and it squeaks when I'm engaging first gear. I still have the original clutch at 176K miles so I suspect it's in the throwout bearing/guide tube area. It's been making this noise occasionally, not all the time, for about two years now so I'm going to let it keep making noise and I think the eventual clutch replacement will cure it.
It's not a brake squeal as it is brought on by engaging the clutch. After the car is warmed up, the noise no longer occurs.
ssoliman (12-16-2021)
