R50/53 I'm going in. Need some ideas...
Old 05-06-2024, 04:55 PM
Boostmaster's Avatar
Boostmaster
Boostmaster is offline
Coolant leak is a small leak where the lower rad silicone hose simply does not clamp tight enough. The rad is new all aluminum, the reservoir is new and everything else is new or in excellent condition. Once I slap on the new heavy duty clamp the issue will be resolved. As for the O2, I have the catless 4-2-1 header. It's just as well made as the stocker with significantly less restriction and a lot more noise. I do not think the stock unit would deliver the power I currently get. As stated earlier, the light affects nothing. It's just annoying.
BTW, the sound inside the car is decent. The stock radio and speakers sound pretty good and I can hear them without resorting to anything drastic. I could use some more sound deadening and I may try that later but I have other projects to attend to.
  #352
Old 05-08-2024, 06:11 AM
Boostmaster
Originally Posted by OutlandishnessDue
awesome you have your car back on the road - what a PIA. just hoping my own terribly packaged luk clutch serves me better - I should know soon enough! Best of luck with the hopefully much smaller headaches that remain
I also appreciate the feedback on that miltek sounding a bit ricey. I saw a couple YouTube videos of the unresonated versions and felt the same. My Invidia exhaust is loud but I love the deep and growly tone - hopefully once I deaden the sound a bit from the inside it will be perfect
My Milltek is resonated but I also have a catless 4-2-1 header that contributes significantly to the noise. On start up it's slightly more than stock. If you are reasonable with the throttle, it's got a nice deep sound. It's really only when you hit that go pedal that she opens up and makes a racket. Since I only do that once in a while, it's ok for me. The car has sound deadening (except in the doors- they sound like a tin can. Red Thunder II, on the other hand, has the doors done and they sound solid) and it's reasonable inside. I think I may add a little more to see if I can get Lexus levels of quiet, but that's just a side projects to keep me entertained. And right now, I have several other projects that need my attention first...
Toblerone999
05-07-2021 12:11 PM
Benjamin Tatham
59
01-24-2021 12:46 PM
steve05ram360
50
11-08-2020 05:57 AM
Cease
12-20-2018 08:48 PM
Boostmaster
01-03-2018 01:39 PM
Quick Reply: R50/53 I'm going in. Need some ideas...
