R50/53 cv axle replacement question
Old 10-11-2024 | 01:41 PM
ssoliman's Avatar
ssoliman
Fcpeuro.com has some options. And lifetime warranty
  #52
Old 10-11-2024 | 02:30 PM
Mforce's Avatar
Mforce
Originally Posted by junits15
Sorry to hijack this thread a little, I need to source an axle for my r53. I'm planning on taking a risk on some axles from napa, anyone ever used their axles? I have more trust for napa parts than stuff from autozone or advance. They come with a warranty, so if they're bad I'll just return them.
I got mine from FCP euro. I went with GKN., why? because this is MINI's OE very close enough or the same as MINI brand.
I got my drive side so far it went through no issues with splines in transmission side and as well on bearing side. I replaced the shaft oils seal on mine with Corteco brand seal.
Here's my original MINI CV shaft... 34 teeth \ spline or whatever tech\mechanical term you want.
For R53.
Transmission side: 34 spline
Bearing side: 26 spline
and here's the GKN remanufactured CV shaft.
  #53
Old 10-14-2024 | 08:38 AM
I did mine on the R52 aftermarket and they were fine. You just have to make sure places have the correct one per the transmission and side, lots of people mix them up selecting the wrong car or side. Or they don't realize auto and manual transmissions. The catalogs of some of those Non MINI focused places also mix up part numbers are they data dump info and overlap models in the 2007 R52 vs R56. We do things more manual here and audit the data. So just be careful with ordering things from other people as you might get the wrong part.
Audiobandit
09-02-2023 04:48 AM
laurel51
R55 :: Clubman Talk (2008+)
07-27-2021 09:22 AM
doomi
15
04-08-2019 05:56 AM
cw40342
06-26-2014 11:12 PM
WinnieMiniFW
01-06-2012 10:24 PM
Quick Reply: R50/53 cv axle replacement question
