R50/53 Clunking From Driver Side Front
Hey all, long time lurker first time poster. I have a pretty wicked clunk developing from my driver side front, it vibrates badly on start-up as well as some low speed driving but at higher speeds / bumps its totally silent. I was thinking this could potentially be an engine mount but when I look up "R53 Engine Mount Replacement" on google it only gives me the passenger side mount or lower mount. Any recommendations or suggestions? It is on a 2004 Mini Cooper S (build date 05/04).
Thanks all!
Thanks all!
On the driver side - that would be the the gearbox/transmission mount :
This is its location
However, I would find it highly unlikely that it is broken or needs replacement. That is not to say that the bolts aren't loose.
Tighten and check their torque.
On the otherhand, a worn drive axle (driver side) may contribute to the clunk and/or vibration while in motion.
On a 1st Gen Mini there are essentially only 2 or 3 (depending on year & model) engine/vibration mounts.
The upper engine mount is located on the right passenger side (just forward of the strut tower)..
There are a few models that also have a vibration damper which is also located on the right passenger side mounted horizontally closest to the firewall and in conjunction bolts the the upper engine mount via a bracket assembly. Not all models have them.
The lower engine mount (affectionately referred to as the "dog bone") is located below the engine which also attaches to the subframe.
A worn lower engine mount may and usually will cause some serious vibration and sometimes a clunk can be heard at times while engaged in gear or on load.
Those engine mounts are most likely to come up in your search results.
univore
05-23-2019 07:02 AM
