R50/53 speedo pin outs needed
If you're talking about the center-mount speedo, then unfortunately it's not that simple.
The GM module controls the headlights/taillights. When it turns them on, it sends a BUS signal to the center speedo which then illuminates the instruments. So the only way to get it to illuminate is to connect it to a CAN emulator and feed it the right information.
However, if you have a steering column mounted tach or speedo, then it's as simple as you' imagined. The center mount speedo just feeds those a 12V signal to illuminate.
Camaroboy14
04-08-2015 08:05 PM
