R50/53 Getting some codes
First thing I would do is pull the wires from the coil and clean the contacts on the coil itself.
If that doesn't do anything, try swapping the wire positions to see if the code moves (this will indicate possible bad wire)
if that doesn't change anything, you may be looking at a bad coil.
Hey @BlwnAway just curious -
I read somewhere that one can determine a bad coilpack on a gen 1 by turning it upsidedown. If the color is white - "supposedly" it is an indication of a bad or near dead coilpack.
Have you ever heard of this??
Thanks.
Thanks.
But I've never really looked.
Yeah, me too.
I pulled my coilpack this afternoon while I was detailing my engine. I turned it over to see the underside poured resin "ballast"/"insulation" is naturally glossy white.
I now think I remember that the poster showed that the bottom of his (bad) coilpack was caulky and dusty white - resembling the corrosion you would see around battery terminals.
His example definitely was convincing to me that his coilpack was indeed suspect of going bad/dead.
Just thought I'd ask
cjv2
07-12-2023 07:35 AM
