R50/53 Dealer costs for Rear Fog Light reprogram?
Originally Posted by erik99
Hi,
I'm considering installing the rear fog light on my own. Anyone know the cost to have the dealer do the ECU reprogram to recognize the light?
Thanks!
Thanks!
Earl
Originally Posted by 10851CS
You don't have your MINI yet?? Your getting an 05 right I thought the 05 comes with the rear fog lights.
Earl
Earl
I do not think it comes with the rear fog.
With any luck, the ship with my MCS should be in Charleston today
No Mini yet. I ordered the LSD which was only available after 01-01-05.
Earl
I ordered my MINI from Classic MINI in Cleveland (highly recommended, BTW!) in mid-Oct and picked it up in early December, 04. About a week before the car arrived, they emailed me a list of programming options and asked me what choices I wanted to make - things like auto-door locks, windshield wiper speed settings, etc. I assume all dealers are supposed to do this. They might be able to add the programming for the fog light at this point. (I don't know if the light has to be physically present or not.) If they can do it before you pick up the car, there should be no charge. Then you can install the light and switches yourself at a later date.
I just installed the 05 rear fog and switches myself last month. My local dealer (Niello MINI in Sacramento) charged me $50 for 1/2 hour labor. I've heard of other dealers charging $45 for 1/2 hour labor. (I am in California, after all - I'm sure it's a "market" thing.) They also programmed the OEM alarm system which I had also installed and did both the fog and alarm for the single half hour charge.
FWIW, I think the rear fog is a necessity if you live in an area where there is heavy fog! I do wish, though, that mine were programmed to operate with the parking lights on and the headlights off. The front fogs work this way. (The xenons really light up fog badly - my forward vision is much better with front fogs (and parking lights) on and the xenons off.)
Lots more info (including part numbers and photos) on this thread: 2005 Rear Fog Retrofit
When I cut the headlights, so that only parking lights are on, any fog lamps that are on, go out. I have been wrong before (well, once ) but I don't believe that this can be changed. I too wish that the fog lights (all of them actually) would light, with only parking lights activated.
Not the brightest bulb in the chandelier,
Tatt
Originally Posted by tattman23
Is that so? That's different than how mine work... must have to do with your having the Xenon headlamps or something, which I lack.
I've emailed my SA asking if it's possible to change the programming so the rear fog works the same as the front fogs (in my car, anyway). Haven't heard back from him yet.
Interesting. My front fogs definitely work with the headlights off and just the parking lights on. FWIW - this is only with the ignition on, too. If I turn off the ignition, the parking lights stay on but the front fogs go off. Weird, huh?
You have a good point about the ignition ON... I KNOW I start my motor before I buckle up (start up ritual, lol) but I can't remember my shut down ritual exactly. Now I have to run out and check .... (sound of sneakers on pavement)...
OK here's the deal (it's awfully nice out, sunny and warm for February in Chicago - tempted to skip out the rest of the work day, shame on me for wantin' to motor - I think I'll have lunch somewhere FAR from here :smile: )..
Ignition ON is where I was going wrong. With it OFF, only the parking lights will operate, no headlamps, no fogs.
With ignition ON, (sheepish who-me grin) I can turn off the headlamps and BOTH front and rear fogs will remain lit. Which leads me to believe you may be wired (or programmed?) slightly incorrectly (your rear fog light, not YOU), since you say the rear fog won't light when you're only running the parking lamps...
Interesting recess and I been meaning to check this out anyway, thanks
Tatt
Hmmmm....I didn't order a rear fog light (but I have dealer installed front ones) and my car came with the switch (and it works too!) for the rear fogs. Does that mean mine is already pre-wired and I just have to add the light?
I was thinking that if they programmed the fronts, the rears are also programmed already.....
Well, I can't speak for Tillie, but I know I've got some strange programming. (The 60s were a *****, man!)
Anyway, did you try this: ignition on, headlights on, front and rear fogs on. Everything is on, right? Now turn the headlights off. On mine, the front fogs stay on, but the rear fog goes off. I'd appreciate hearing how yours work.
07-16-2020 12:54 PM
12-23-2015 10:36 AM
