Very close - and a good attempt. German can be a little tricky. More likely it is g - trog (short "g" as in "go", emphasis on the second syllable). But who really cares??
Its pronounced more like "ge - traag", with the "ge" being a fairly short sound. The "t" goes with the second syllable, and the "a" is drawn out, like "ahh".
It's not "trag" It's definitely a "TROG" sound. Not sure about the first part. I believe Michigan MIniac is right. But it's definitely a "TROG" sound. I know I read that somewhere a while back.
The "o" in frog is linguistically very similar to the "ah" sound in Getrag, only the "o" is pronounced slightly lower in the mouth. Mind you, I'm not referring to pitch when I say lower; rather, it is a term that linguists use to identify vowel sounds. To many people's ears, the sounds are very close.
If you are familiar with the German music group Kraftwerk, then you can compare the "a" sound: it sounds essentially the same in Getrag as is does in Kraftwerk (which is not pronounced like the cheese company Kraft, where the "a" is much higher and has what most people would refer to as a nasal quality).
